Author Topic: Rear Brake Plate for a Rickman Zundapp  (Read 1151 times)
Offline Blake W
« on: November 08, 2015, 11:24:02 pm »
Hi all, I went to fit the brakes to the rear brake plate on my Rickman Zundapp restoration and figured out that I have the wrong brake plate. The brake plate I have is off a Rickman Montesa, or a later Rickman Zundapp with a cush drive hub. These had the brake plate on the clutch side (left hand side viewed from the front). The brake plate I need is on the opposite side (drive chain/gear shifter side for the Zundapp motor) for a conical rear hub.
Any info on where I can get one would be much appreciated!
Blake
