Author Topic: any one used JBS shocks  (Read 19274 times)
Offline Andrew L
Re: any one used JBS shocks
« Reply #16 on: October 30, 2015, 03:46:20 pm »
Jeez Cyclegod thays are might fancy rear end holder upperators ya got there
Hey Andrew they almost look like the stock item :o ;D :D :) ;)
Offline Tomas
« Reply #17 on: October 30, 2015, 04:42:54 pm »
I got 2 sets of used ohlins shocks each for around 250 shipped from US. Most of ohlins, fox, works performance can be rebuild,tuned and parts are available.  Shims, seals,o-rings etc. Buying cheap shocks will not save you money since you will have to replace them when they break and that will cost you more money. Great about ohlins shocks is that you can adapt bodies and shafts to suit your bike. All you need is a lathe. Its soo easy  :)
Offline Andrew L
« Reply #18 on: October 31, 2015, 09:08:45 am »
They look and fit the same as the Honda ones except these have oil in them and the originals don't , even down to the shape of the plastic spring guide.
