Marque Remarks
Yamaha
1974 MX-250 swing arm question.
Pages:
All
Topic: 1974 MX-250 swing arm question. (Read 15436 times)
LWC82PE
Superstar
Re: 1974 MX-250 swing arm question.
Reply #15 on:
October 15, 2015, 12:41:40 pm »
The tolerance is for what ever country that site is from. Its not relevant here. I just ignore that. The formula is good though. I checked it against my manual measurements from compressing the rear end and the result was exactly the same as just entering the data and letting the calculator do it. I normally play around with the measurement to the axle and the actual shock stroke to see what difference it makes in wheel travel. Sometimes just a few more extra mm shaft travel can have a dramatic increase in wheel travel. I normally include ½ to ¾ compression of the bump stop depending on material/design.
Husk72
B-Grade
Attitude? What effing attitude?
Reply #16 on:
October 19, 2015, 03:28:32 pm »
That's a cool calculator, LWC. No longer in the dark regarding lengthening a swingarm.
Thank you for posting it up.
Cheers, Mark.
I used to drink a lot.
I still do,but I used to,too.
Pages:
All
Marque Remarks
Yamaha
