Author Topic: MX/DT 360 PISTONS  (Read 8101 times)
MX/DT 360 PISTONS
« on: August 25, 2007, 05:06:38 pm »
hi
can pistons be ordered for these engines or do you have to troll through ebay and other listings like i have to with my 1979 yz400f.it looks like you can get 250s but i already have a 1973cr250,looking for 350+ to go in my antig slider frame.
Re: MX/DT 360 PISTONS
« Reply #2 on: August 25, 2007, 06:50:27 pm »
so rt1 pistons are the same as mx360 or yz360 pistons
jimg
« Reply #3 on: August 25, 2007, 08:54:21 pm »
Might need to cut some holes in the buggers?? you know for reed valve transfer 7 port as opposed to 5 port thing non reed valve thingo stuff....please correct me if wrong. Tim
« Reply #4 on: August 25, 2007, 10:49:30 pm »
jimg
I wouldn't assume it! Even with holes cut for the reed valva inlet I would measure.
My experience has mainly been with RD's, RZ's, Banshee's and LC's and with these there is a lot in common but enough differences with skirt height, weight and dome to be carefull.
Measure and check is my advice. The difference is between just working and working well (performance).
« Reply #5 on: August 27, 2007, 11:07:10 am »
I've got a brand new standard size DT piston you can have if you want it.
« Reply #6 on: August 27, 2007, 04:32:49 pm »
i have full sets of both the MXA /DT360A pistons, what O/S are you after ?  a couple of them i have double ups, if its one of those i can sell you one, also have rings for most Sizes in the 360's also same deal.
cheers Freaky
« Reply #7 on: August 27, 2007, 04:39:22 pm »
Cycle god did you suss out the 8th oversize ? is that a size hehehe ( 2mm sounds more respectful)
I think the RT use the dyke rings like the early DT so the piston crown is differant and thesection is missing where the 'L' ring sits, they look the same kinda otherwise so i guess you could buy it and see, i have been buying up a lot of those shift cams ( after my last experiance) from that seller and he always post quickly if thats any help
