Author Topic: 1976 YAMAHA YZ 125 C  (Read 21053 times)
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: 1976 YAMAHA YZ 125 C
« Reply #15 on: June 15, 2015, 08:16:52 pm »
who gives a shit...
its a pre~78 jobby and theres still heaps of parts available for em...
"flat bickie"
« Reply #16 on: June 16, 2015, 07:37:35 am »
Was there ever a B model? And the only difference between C and X is the forks?
« Reply #17 on: June 16, 2015, 08:08:32 am »
The B was a white A.
Changes from a C to an X:
34mm carb;
Longer swingarm with chain tensioner;
Longer shock;
Forks & triples;
520 chain & sprockets (inc rear sprocket becoming flat rather than dished);
Rear hub (to suit flat sprocket)
Barrel and head;
Bigger stinger on exhaust;
Ignition & ignition cover;
Beefed up frame around rear engine mounts;
Better footpegs mounts;
Slightly bigger footpegs;
Front guard has cut outs to clear the fork boots;
Colour.
« Reply #18 on: June 22, 2015, 01:54:57 pm »
I have a 76 yzc125 roller frame with a 125DT motor, a spare YZ125 motor and a other bits that might fit it ....  cheap.  (well enough to cover the price of the wheels and forks if i used them for other projects or maybe would swap for A parts or cash)
« Reply #19 on: June 22, 2015, 01:57:35 pm »
i JUST SOLD  an A and a B recently exactly the same except the serial start with a 1.... and the B was yellow the A was silver.
the c's i have previously sold have been white and red.
« Reply #20 on: June 22, 2015, 01:59:53 pm »
Also have another a YZA125A  apart for sale and maybe a 250A as well, stack of DT250s for pre and post 70 class. and aKwaka 125 motor assume its a 74.KE if anyone keen to get it out my shed. PE steal Tank and all matter of TM small stuff in a box.
