Clubroom
Bike Talk
84 YZ250L selector shaft replacement
Topic: 84 YZ250L selector shaft replacement (Read 6142 times)
DIRTPILOT72
A-Grade
May 17, 2015, 08:02:00 pm »
I had an unfortunate chain derail that has the selector shaft bent near the gear lever spline. Cases look ok and no oil leaks. Can you replace the shaft through the right hand side clutch cover or do the cases need to be split? Are the gear selector shafts still available?
Honda XR200 x2
Honda XR250
Yamaha Yamahopper QT50
Paul552
HEAVEN #552
Re: 84 YZ250L selector shaft replacement
May 17, 2015, 08:13:47 pm »
Yes you can.
Not sure if you can buy them
'77 YZ125D '84 CR250RE '89 CR250RK '84 CR80RE '09 YZ250F
DIRTPILOT72
A-Grade
May 17, 2015, 08:21:56 pm »
Thats what i wanted to hear.
Honda XR200 x2
Honda XR250
DIRTPILOT72
A-Grade
May 17, 2015, 08:26:25 pm »
Found a 85 used one, i assume that 84 and 85 are the same?
Honda XR200 x2
Honda XR250
Nathan S
Superstar
HEAVEN #818
Reply #4 on:
May 17, 2015, 08:46:43 pm »
Be amazed if they're not the same. Try looking at part numbers on partzilla or yamaha-motor.com
fred99999au
A-Grade
Reply #5 on:
May 17, 2015, 08:58:11 pm »
Have a good think about how ou will replace it though before you start. You don't want to go smashing a bent shaft through clean bearings and seals, and may need to cut it off at a straight bit or bend it back somewhat.
DIRTPILOT72
A-Grade
Reply #6 on:
May 17, 2015, 09:55:36 pm »
Yeah, i am going to get a bike mechanic to do it, probably wise to cut the end off.
Honda XR200 x2
Honda XR250
DIRTPILOT72
A-Grade
Reply #7 on:
May 17, 2015, 10:01:45 pm »
Yep, 84 and 85 seem to be the same. And avaible NOS. Thanks everyone.
Honda XR200 x2
Honda XR250
Clubroom
Bike Talk
