Author Topic: TM400R Flywheel Weight  (Read 11701 times)
Re: TM400R Flywheel Weight
« Reply #15 on: May 15, 2015, 09:39:29 pm »
razor band is apparently due to crook advance curves on tm's. ts ignition provides more stable ign curve I believe.
« Reply #16 on: May 15, 2015, 09:48:04 pm »
Avoid riding them like the plague. Been there and done that.
Offline Momus
« Reply #17 on: May 15, 2015, 10:35:10 pm »
Ideally you would make an aluminium split ring clamp to hold the flywheel tight in a vice and another tool to attach to the weight.
If it where my job I would drill and tap the 3 holes to M8 and make a matching bolt on flange and weld that to a 600 mm long bit of RHS or bar as the unwinder
I would then gently heat the threaded area with a welding tip oxy flame and watch for the telltale puff of smoke that comes out when you have killed the loctite- assuming there is any.
Prior to that I would have given it a good soaking with CRC.
Failing that, this:
http://www.ebay.com/itm/1971-SUZUKI-Cyclone-400-TM400-TM400R-FLYWHEEL-ROTOR-/361234746822?hash=item541b44cdc6&vxp=mtr
A new weight would be a simple job for any machinist.
If you love it, lube it.
Offline TIKI
« Reply #18 on: May 16, 2015, 05:15:56 pm »
Thank you all for the reply’s and advice, I think at this point I will see if I can at least get it started and evaluate where I go from there. I did ride this a few years ago when I first bought it so the timing should be close as it sits. I just finished going through the carburetor which was leaking out of the overflow I tried setting the float level multiple times, tried a new needle and seat  and found the brass overflow tube in the bowl had split from top to bottom. I had another float bowl which solved that issue so tomorrow I will try to fire it up.
1976 Yamaha DT400C , 1973 Kawasaki Z1 900 , 1971 Suzuki TM-400R Cyclone
Offline TIKI
« Reply #19 on: May 18, 2015, 08:30:36 am »
If it won't come off leave it on and time it by other means. I can explain how or if you are close do it for you.
Sleepy can you describe the timing process for me, my manual does not give a lot of detail on the process other than using a timing light but that is to check the timing while running and I am trying to get it running.
Offline sleepy
« Reply #20 on: May 18, 2015, 10:46:49 am »
I sent you a PM
