Author Topic: DT360 CRANK SEAL REPLACEMENT  (Read 5795 times)
« on: July 21, 2008, 10:31:13 pm »
HI
i have to replace the crank seals in my dt360a.the stock ones are 10mm deep and off the shelf bearing shop ones are 7mm deep.will these work or should i use gen yamaha if i can get them.
also the best way of doing the job.ie in the bike or motor on the bench.
thanks
jim
Re: DT360 CRANK SEAL REPLACEMENT
« Reply #1 on: July 21, 2008, 10:49:31 pm »
Been there J and I remember buying the 10mm Cheap of the shelf from local bearing shop. (NSK Brand ) I already had engine on bench. Cheers Tim
« Reply #2 on: July 22, 2008, 08:58:04 am »
so the bearing shop ones are ok but must be 10mm not 7mm.
Offline matcho mick
    • Moto Tumbi
« Reply #3 on: July 22, 2008, 01:14:41 pm »
hey Jim(crasher  ;)),woulda thought the ign side  crank seal was ok? ;D (seeing as you got down to #200 mj  ::),didn't catch up to see how it went,cheers mick
« Reply #4 on: July 22, 2008, 05:27:13 pm »
CAN ONLY GET 7MM has any one used these on there bikes.can buy ome 68.20 and 48.35.off the shelf 7mm are about 8.00 each.
« Reply #5 on: July 22, 2008, 06:40:22 pm »
MICK
i got sick of you throwing dirt in my face so i thought i would have a little rest and through dirt in my own face.plug was still black and wet also the crankcase oil level was not on the dip stick any more.
« Reply #6 on: July 22, 2008, 07:14:52 pm »
Myself I would try it, Probably get shouted down but I believe the 7mm ones will have equal sealing qualities. Tim (I did those seals about 12 years ago but surprised that they appear NLA)
« Reply #7 on: July 22, 2008, 07:29:15 pm »
a few questions.
1. as a comparison how much are OEM 10mm width seals ?
2. can you replace them if needed again without splitting cases ?
if the answer to one is not much in price then i would go the OEM (piece of mind)
if answer to 2 is no then go oem (why take a risk for $20-30 and go through the same excercise again).
« Reply #8 on: July 22, 2008, 08:13:27 pm »
I'll work.
In fact, the thinner seal will almost certainly run on a different part of the sleeve, away from the groove that has probably worn into the sleeve by now...
The possible issue isn't the width of the seals (genuine vs aftermarket), its the design. The genuine ones are 'two-way' seals, with two sealing rings, back-to-back.
In theory, this is important to ensure the seal works both ways (gear oil out of engine and fuel out of gearbox), but in reality, I've never seen or heard of it being a problem.
Offline DJRacing
  • YZ125X
« Reply #9 on: July 22, 2008, 08:14:54 pm »
Jim, Speed and sport (USA) have one crank seal 93103-38086-00 (38mm-62mm-10mm) for $us42.75
Ask your local yamaha shop to do a stock seach which will let you know if any of the seals are in any of the other yamaha shops in australia.
93103-30072-00    30mm-62mm-10mm
93103-38086-00    38mm-62mm-10mm
Failing that there are after market seal makers and most bike shops have there books/listings and other brand bikes my use the same seal.
I hope this is of some help to you.
« Reply #10 on: July 22, 2008, 09:50:50 pm »
HI
the seals are 68.20 and 48.35 nos in australia the aftremarket ones are about 8.00 each and are double liped.crankcases dont have to be split.looks like an easy job to do.i have checked in the usa and 43.00 and 15.00 for the same as here plus about 9.00 postage.
« Reply #11 on: July 23, 2008, 12:06:26 am »
wherent they the same seals on all the 74 mx models as well, should be something going around specially in Resto circles
