Author Topic: Yamaha SC 500  (Read 4590 times)
maxvmx
Yamaha SC 500
« on: April 24, 2015, 09:15:05 pm »
Apart from the tank colour and decals what's the difference between a 1973 and 1974 SC 500?
Re: Yamaha SC 500
« Reply #1 on: April 26, 2015, 01:35:03 am »
None that I know of it was just a follow on model . Iain
Offline YZB 500
Re: Yamaha SC 500
« Reply #2 on: April 26, 2015, 08:54:44 am »
Hi ya,
Shift drum is longer on the 74, changes in the shift mechanism.
and the 74 went to a needle roller bearing in the clutch actuator shaft.
and some gearbox internals, close ratio to wide ratio
also the big end in the early parts books is a 19 needle roller bearing, give that a miss, the 17 needle roller bearing is the go! I had a 19 needle roller bearing big end fail, the cage is strong in the case of the later part numbered big end bearing.
Regards YZB 500
« Last Edit: April 26, 2015, 09:44:21 am by YZB 500 »
Old school is cool !
Offline bazza
Re: Yamaha SC 500
« Reply #3 on: April 26, 2015, 09:47:53 am »
CDI unit and one was faster than the other! You could swap between 2 models and it made the difference in speed as to which would be faster. 2 mates measured barrel, ports etc trying to see why one model was faster,in end they found japanese info on CDI, swapped and it made the difference
« Last Edit: April 26, 2015, 09:49:37 am by bazza »
Embrace patina
Re: Yamaha SC 500
« Reply #4 on: April 26, 2015, 10:07:00 am »
Well you learn something new every day . thanks gents . Iain
