Marketplace
Wanted
MUGEN 360 PISTON AND CR250RZ kickstart assembly
Topic: MUGEN 360 PISTON AND CR250RZ kickstart assembly (Read 3229 times)
g465b
B-Grade
February 17, 2015, 06:40:14 pm »
hi , chasing a piston/rings to fit 83.5mm bore of a NOS 360 Mugen barrell, any brand-even if it needs machining/modifying. also a
complete kickstart assembly to fit the 78/79 Cr250 honda ,shaft,gear,ratchet thing and spring and lever . thanks g.
bigk
Kangaroo Flat Victoria
Re: MUGEN 360 PISTON AND CR250RZ kickstart assembly
February 17, 2015, 07:26:51 pm »
You can use a Montesa 360 piston with minor (easy ) mods. Might be easier to locate. One piston maker in Melbourne has the specs and has made Mugen pistons in the past.
g465b
B-Grade
February 17, 2015, 07:37:30 pm »
thanks K pm sent
Rossvickicampbell
February 17, 2015, 07:58:13 pm »
small help - but expensive - check out Phil Denton Engineering in the UK for kickstarter levers - have the re mortgage ready.
JohnnyO
Qld
Reply #4 on:
February 17, 2015, 09:39:19 pm »
Rick Horvat in the US has 360 Mugen pistons
g465b
B-Grade
Reply #5 on:
February 17, 2015, 09:43:42 pm »
thanks ross,john and rodger. cheers Grant
Marketplace
Wanted
