Author Topic: Pre 1975 reed valved CR125M  (Read 23695 times)
Re: Pre 1975 reed valved CR125M
« Reply #15 on: February 17, 2015, 12:28:24 am »
My GEM reed had 4 bolt holes like std and as I've said it bolted straight on and was very close to the length of the std manifold so the carby fitted properly also. No machining was required although I did match it to the inlet port.
My reed block was vertically split but it was shaped like a W not a V and had 12 reed petals. I did away with that setup because the cage was bulky and too restrictive. I fitted a 6 petal horizontally split yamaha reed cage inside the GEM housing and it worked brilliantly.
I would say your GEM reed was not for a Honda because it was nothing like mine and I had 2 the same for CR250M's.
« Reply #16 on: February 17, 2015, 01:09:19 am »
I have the GEM catalogue. There were several fitments
CR250 74 and earlier #5342 (V12 reeds) - only requires piston mod
CR250 & MR250 75 and later #5372 (V12 reeds) - only requires piston mod
MT250 & Odyessy #5348 (V12 reeds) - some machining/mods to exterior of inlet port is necessary. Installation of boost ports is recommended
CR125 75 and earler using stock carby #5340 - no mods required
CR125 75 and earlier using 30-34mm mikuni #5346 - no mods required
CR125 76 and later using stock carb or 30-34 mikuni #5338 - requires some re-shaping and slight modification to inlet port
Boost ports recommended on earlier models but GP 75 and 76  cylinders only require minor mods in this area
MR175 stock carby #5352 (V4 reeds) - no mods required
MR175 with 30-34 mikuni #5353 (V4 reeds)- no mods required
Boost ports recommended for max performance
MT125 with stock carb #5354 - no mods required but some slight grinding of the cases needed. Boost ports recommended.
« Last Edit: February 17, 2015, 01:25:12 am by LWC82PE »
Offline KB171
« Reply #17 on: February 17, 2015, 09:14:25 am »
Standard CR250 barrel & what i believe is the Gem setup  that was avalible at the time, Did they work unmodified ??
« Last Edit: February 17, 2015, 09:22:17 am by KB171 »
« Reply #18 on: February 17, 2015, 09:34:31 am »
That's the one KB, thanks for the pics.
They work ok std but I cut the centre out of my housing  and used a Yamaha reed cage.
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #19 on: February 17, 2015, 10:48:22 am »
Yep, that's similar to what was on my Elsinore KB. I should of mentioned that my GEM had the twin reed block with 3 petals on each side of the V. In total 12 petals. Maybe the GEM reeds I had were not meant for the CR??? I id buy the setup 2nd hand so maybe it was modified before I got it.....
Fitting the 6 petal reeds from a later model bike would be the go for sure. As Johnny said, I would think the 12 petal set up is restrictive in comparison to a horizontal set up.
« Reply #20 on: February 18, 2015, 12:11:13 am »
The Mossberger is a 4 bolt to the cylinder and 4 bolt to the cage takes 'another' Honda cage and stuffer that is the best set up. Hmm have a drawing of the Mossberger housing  who does casting...............
The GEM reed cage is far from restrictive has lots of tip area which is exactly what V force did.
« Reply #21 on: February 18, 2015, 04:18:29 am »
i finally know what bike/models the after market reed setup fits that i got from the wreckers now so anyone want to buy as it wont fit what i brought it for without alot of work in adapting it to fit my rms125,thanks KB171 for posting the pics of it
« Reply #22 on: February 18, 2015, 07:43:50 am »
Lozza you got a drawing to reed up the H2 ? > Thats a thought I am playing with .
There is a place in the states who does reed valve conversions for H2s, will see if I can find the details after work tonight
« Reply #23 on: February 18, 2015, 09:28:00 am »
Would be very easy if you have access to a CNC machines ..... ;)  John Aylor or JaMoo is what he goes by on many forums who makes the reed conversions. Need to do the cylinder as well to get the most from it.
« Reply #24 on: March 01, 2015, 05:21:45 pm »
Here you go Walter
http://www.3cyl.com/mraxl/aylor/
« Reply #25 on: March 01, 2015, 06:54:56 pm »
Pre 75 Hodaka 125 Super Combat MX, Great smooth power from it's stock read valve set up, standard ( OK close ratio) shitfull gearbox..... ::)
