Author Topic: anyone know what this suzuki wheel is  (Read 5975 times)
« on: January 20, 2015, 11:13:50 am »
got it with some flattrack stuff
jim
Re: anyone know what this suzuki wheel is
« Reply #1 on: January 20, 2015, 11:19:47 am »
What year is stamped on rim ?
Offline Doc
« Reply #2 on: January 20, 2015, 01:49:32 pm »
TM250/400 wheel with TS250/400 brake backing plate ;)
« Reply #3 on: January 20, 2015, 02:56:48 pm »
What size rim ?
Doc would be damn close if not spot on as usual
Offline Jumbo J
« Reply #4 on: February 11, 2015, 06:02:11 pm »
Bit of a wired sprocket cush drive set up there, whats going on with that
« Reply #5 on: February 11, 2015, 06:32:34 pm »
If you look closely ...it appears the bolts pass thru an adpt ... possibly an old sprocket minus it's teeth, and the other bolted to it.
Offline Jumbo J
« Reply #6 on: February 11, 2015, 08:16:46 pm »
I just thought it looked a bit unusual having one sprocket on top of another like that, figured it would throw out the chain alignment, and would need to be removed to fit a std TM250 setup. A fairly precision machining job too (for a layman) ensuring no runout.
Was only curious to know what application it might have been set up that way for.  Anyway i am interested in it for my TM for quick tyre swaps.
« Reply #7 on: February 11, 2015, 08:20:27 pm »
I think thats the key to the mystery
 RL250 ran dished sprockets
Offline Jumbo J
« Reply #8 on: February 11, 2015, 08:25:52 pm »
Trilas riders are an inventive bunch. Good in the machine shop too by the looks
« Reply #9 on: February 11, 2015, 08:42:44 pm »
 i think trials riders dont like spending money
 thats why they have tiny seats and dont wear their boots out by letting them touch the ground.
 ;D  ;D  ;D  ;D
Just kidding guys
dished sprockets are pretty hard to come by now and some guys turn the teeth down and weld on a  new ring
not sure what the brake hub is from but looks TS
Offline Doc
« Reply #10 on: February 11, 2015, 11:05:47 pm »
one small issue..RL250's use RM125M/A hubs on the rear (non cush drive) ;)
Offline Jumbo J
« Reply #11 on: February 12, 2015, 07:13:14 am »
thanks for that pearl of knowledge Doc
the pressure on a trials bike drive train would be far less  than on an MX or DT - right.
so i can appreciate that a cush drive would be  easier on the gearbox. Is a solid drive on the 250 likely to be an issue for DT and MX, given that it is used on the early RM125's albeit with (slightly) less HP than a 250.
« Last Edit: February 12, 2015, 11:50:42 am by Jumbo J »
« Reply #12 on: February 12, 2015, 09:23:15 am »
Could be early - very early (like, '69) TS.  Is the rim steel?  The first few TS's came with steel rims front and rear, and whacking heavy hubs and brake plates (ex-Hustler).
Offline MaxPower
« Reply #13 on: February 16, 2015, 01:52:50 pm »
I would say DR400 but it has a chrome brake arm so maybe a sp400?
