Author Topic: Yamaha XT 250 parts needed  (Read 1327 times)
maxvmx
« on: January 02, 2015, 10:26:32 pm »
Hi,
I’m hoping someone with some XT Yamaha bikes surplus to needs can help? I have a fairly late model XT 250 (2 valve model) that I’m after a few bits and pieces for.
Rear brake lever, rod and actuating arm.
Headlight with mount brackets.
Speedometer with mounting plate.
Engine decompression arm and cable.
Stock OEM muffler.
Left and right side handle bar switches
Any help / leads would be most welcome.
Re: Yamaha XT 250 parts needed
« Reply #1 on: January 03, 2015, 10:05:02 am »
I should be able to help out with most of that, I'm on hols at the moment but will be home on the 12th or so.
Although I'm up in the Kimberley so freight could be a bit hexy depending on where you are.
