Marketplace
Wanted
85- 89 Suzuki DR200 Throttle tube
Topic: 85- 89 Suzuki DR200 Throttle tube (Read 2045 times)
mposs
B-Grade
December 29, 2014, 05:47:41 pm »
Hi, Chasing a good used throttle tube to suit a 88 DR200 Suzuki. Pulled the grip off mine as throttle was tight and found most of the plastic missing.
Cheers Mark
Momus
Re: 85- 89 Suzuki DR200 Throttle tube
December 30, 2014, 12:12:41 pm »
Have a look:
http://www.alpha-sports.com/suzuki_parts.htm?q=suzuki-parts
Those twistgrip tubes are listed as available new in the US and should be available here.
If you love it, lube it.
Tim754
Northern Country Victoria
December 30, 2014, 03:39:29 pm »
Momus is spot on ,They are at your local Suzi dealer .. and there are (well used to be ) aftermarket jobs too. Suzuki Agi200 Trojan is same I think
Last Edit: December 30, 2014, 09:01:06 pm by Tim754
mposs
B-Grade
December 30, 2014, 04:58:54 pm »
Thanks for the replies. I didn't think they would still be available from Suzuki. Will give the local shop a try. Cheers
December 30, 2014, 05:39:13 pm »
Yes, I reckon the Trojan item would fit. Also Suzuki are about to release a new budget DR200 trailie too, so that one will probably fit as well.
Marketplace
Wanted
