Author Topic: 83 -84 KX 250 Swing arm  (Read 5970 times)
Offline Moto
« on: December 08, 2014, 09:22:06 pm »
Would any one be able to measure up a 83/84 KX 250 swing arm for me.I want to use one on a project and need to know if it is close to fitting.
Inside distance between the wheel end.
Outside distance at the swing arm pivot end.
Gap between the swing arm pivot bearings.
Length of pivot bearing housings
Length from swing arm pivot  centre to very end of the arm.
Axle size.
Thanks.
Offline Hardo
Re: 83 -84 KX 250 Swing arm
« Reply #1 on: December 08, 2014, 09:32:14 pm »
I can easily answer all that for both 83 and 84 tomorrow mate. I have both an 83 and an 84 KX250 swingarm here.
Offline Hardo
« Reply #2 on: December 11, 2014, 09:38:06 pm »
Okay, this is what I measured:
83 KX250 Swingarm (Gold):
1. Inside distance between the wheel end = 219mm (outside at wheel end is 240mm)
2. Outside distance at the swing arm pivot end = 192mm
3. Gap between the swing arm pivot bearings = 112mm
4. Length of pivot bearing housings = 40mm
5. Length from swing arm pivot  centre to very end of the arm = 625mm
6. Total length = 641mm
84 KX250 Swingarm (silver):
1. Inside distance between the wheel end = 203mm (outside at wheel end is 264mm)
5. Length from swing arm pivot  centre to very end of the arm = 631mm
6. Total length = 648mm
Hope that helps mate,
Hardo  :)
Offline Moto
« Reply #3 on: December 12, 2014, 01:13:38 pm »
Thanks for the great info Hardo :)
Offline Hardo
« Reply #4 on: December 12, 2014, 08:42:04 pm »
Offline ELC hunter
« Reply #5 on: December 31, 2014, 08:42:23 am »
Tony I could drop one round to you if you need to eyeball one in person.
Offline Moto
« Reply #6 on: December 31, 2014, 08:14:35 pm »
Thanks Gav,I will be in touch
