Author Topic: Gibbits YZ490A  (Read 56822 times)
Offline Gibbit
Re: Gibbits YZ490A
« Reply #45 on: March 05, 2015, 11:35:55 pm »
We had our first mx practice day here in Gundy for the year and I ran it a few times. Ran like a dream. Started first kick and no pinging. Bloody rims have started cracking at the joins again tho, so that's the next thing to replace.
1990 YZ490A
Offline Marc.com
Re: Gibbits YZ490A
« Reply #46 on: March 09, 2015, 12:11:08 pm »
 Rims will crack a mile before they tear and inch, bit of cracking is pretty normal
Offline Gibbit
Re: Gibbits YZ490A
« Reply #47 on: March 10, 2015, 12:21:25 pm »
Thanks mate.  I cant afford new ones at the moment so they will have to be right for a while.
1990 YZ490A
Offline Gibbit
Re: Gibbits YZ490A
« Reply #48 on: March 11, 2015, 10:01:32 pm »
1990 YZ490A
Offline alexbrown64
Re: Gibbits YZ490A
« Reply #49 on: March 11, 2015, 10:14:58 pm »
Good to see the big 490 getting a work out and some big air.  Good work and glad you got it running well.
Offline Gibbit
Re: Gibbits YZ490A
« Reply #50 on: March 12, 2015, 11:16:54 am »
Posing.
1990 YZ490A
Offline Gibbit
Re: Gibbits YZ490A
« Reply #51 on: March 20, 2015, 12:33:02 pm »
I fitted some YZ450F foot pegs.  You can see why in the photo.
1990 YZ490A
Offline Gibbit
Re: Gibbits YZ490A
« Reply #52 on: April 23, 2015, 09:25:15 am »
Steg Pegz fitted.
 I just made a template out of tin and took it to bloke who does laser cutting and he cut it and folded it for $80.
 Then I stripped the bike back and another mate tig welded some tags to the frame for me.
1990 YZ490A
Offline Gibbit
Re: Gibbits YZ490A
« Reply #53 on: November 05, 2015, 11:03:49 am »
Hooking into it now.
The further I get into it, the happier I am with the condition of it all. I split the box last night and the gears are great. All the gear dogs are nearly perfect. Some of the bearings are a little notchy but I was replacing them anyway. Crank is OEM so I will recondition it with oem parts.
I pulled the forks apart tonight and they are pretty good too.
I have put together oem parts list of everything I want and it is about $2,400 if I buy here in Aust. or $1,300 from the U.S. Even with the crap exchange rate. Something I did notice is that there are actually more parts available here in Aust than in the U.S. It may say 'no longer available' on the U.S. Websites but Aust has them in stock.
A brand new FMF system is ordered as well.
This week I have to try and match the silver paint for the swingarm and lower forklegs before I bead blast them. I think I will just take them to my mate who is a panel beater to match it. He also says that he has a special clear coat that's virtually indestructible.
The engine cases will be bead blasted as well. I think I will just use the VHT gloss black on them and the VHT primer and clear coat.
I've nearly got the steering damper sorted, so then the frame can be sand blasted and painted. I think the colour called 'Radical White'.
1990 YZ490A
Offline Gibbit
Re: Gibbits YZ490A
« Reply #54 on: November 05, 2015, 07:20:00 pm »
More bits turned up today.
1990 YZ490A
Re: Gibbits YZ490A
« Reply #55 on: November 05, 2015, 08:29:43 pm »
trick looking pipe are they not?
Offline Gibbit
Re: Gibbits YZ490A
« Reply #56 on: November 05, 2015, 08:49:38 pm »
Doesn't give it a real factory look, but it's what everyone had back in the day.
1990 YZ490A
Offline Gibbit
Re: Gibbits YZ490A
« Reply #57 on: November 11, 2015, 06:49:25 pm »
Got some bits back from the blaster today.
1990 YZ490A
Re: Gibbits YZ490A
« Reply #58 on: November 19, 2015, 07:12:18 pm »
use a satin etch primer on the cases, pretty tough and looks good.
Offline Gibbit
Re: Gibbits YZ490A
« Reply #59 on: November 20, 2015, 11:01:32 am »
I went down the dupli-colour path with high temp engine primer, then enamel and finally a flame proof clear coat.
I went with the gloss black, but I'm not happy with it (too shiny).  I think I should have gone semi gloss.
I'm tempted to blast it and re-paint it again.
Its not a good photo but you get the idea.
1990 YZ490A
