Author Topic: 1979 RM80N Roach  (Read 57422 times)
0 Members and 7 Guests are viewing this topic.
Offline alexbrown64
Re: 1979 RM80N Roach
« Reply #45 on: December 18, 2014, 08:56:32 pm »
Hi Alex, took some pics of my RM125B and 100% original CR125RZ (like your B it has everything original and in great condition incl tyres and sprockets etc) - I'm actually having trouble uploading the pics here - isn't it simply using the insert image button? My second 125B is a bit rough and needs work. I don't have the home workshop and time atm so thinking of sending it away to a dealership or find a restoration workshop to give it a bit of spit and polish - just enough to take out on weekends. Looking forward to seeing the bikes once the tanks are on - fantastic job!
Thanks for the reply's fellas... the little fella loves it and can just stand up on it on tippy toes.. may have to drop the forks an inch.
Mal, you have to use a hosting service to upload pics.. such as photobucket.  Easy enough but a pain.
Alex
« Reply #46 on: December 19, 2014, 09:25:10 am »
You have  good eye for detail, great work mate
Offline alexbrown64
« Reply #47 on: December 27, 2014, 03:41:55 pm »
Thanks fella's on the positive remarks.  Well, when i picked up the tank for the B from Rod, "RedAlert", he also had the tank and front fender ready for the N.  What i job he has done.  It has come up perfect.  He used the same Rolls Royce match that is identical to the OEM guard i provided.  I fitted everything up this morning and also connected the carby properly and installed the pipe.  All fitting up nicely.  The right side still needs some work as parts are coming to finish off the clutch and a few other things. Then it will be ready for tuning, testing and running in.  Young fella saw it and had a grin from ear to ear.  This bike has been rebuilt taking into account that it will be ridden by the young fella.  New airfilter, new rod, all new bearings and seals, rebore, piston and rings, new rear shocks, rebuilt front shocks, new wheel bearings, chain and sprockets, chain tensioner etc...
Big thanks to RedAlert for the great job on the tank and front fender and everyone on here for input and support.
Pics below of semi-finished bike...
Alex
« Reply #48 on: December 27, 2014, 07:04:57 pm »
How cool is that! Well done.
Offline alexbrown64
« Reply #49 on: January 10, 2015, 05:34:11 pm »
Thanks mainline... my boy loves it and it brings back memories for me too.
Anyway, i finally finished the rebuild today.  There are a few small tweaks and adjustments but overall its finished.  Yesterday, i got it back together but there was a problem with the tranny.  I kinda thought there would be as i knew my shift pawl wasnt lining up perfectly but didnt realize at the time that i could adjust it.  After some serious thought and stripping it back down, i discovered the set screw that has a cam on the back but i have never noticed without my reading glasses.  Pic of problem below...
And the set screw that is cammed at the back but i never noticed... well, i adjusted the pawl using the cam on the set screw and got it aligned like the pic above.. Here is the set screw showing the cam section. Its only 2mm but makes a huge difference.
And finally, below is a pic as its sits after i took it for a test ride in the park next door.  Run it through the gears and it is like butter.  Clutch works great and motor is tight but great.  Started 4th kick and idled well and has a nice snap and sound.  The last things to do is a fix the steering lock as the forks touch the tank, shim the top mounting bolts of the shocks as they bind slightly and then just go around and loctite nuts and bolts, check everything over and give it a good wash.  Then it will be ready for running in and more checks.
Alex
Offline b490
« Reply #50 on: January 10, 2015, 05:59:19 pm »
  Magnificent !  ;D   Well done
 Love the look of all the  RM / N models   big & small .
  Nice to see this little machine resurrected  .
 Regards ,
                 Steve
Simo63
« Reply #51 on: January 10, 2015, 11:00:36 pm »
Top job Alex  8) 8) 8)
Offline mudguard
« Reply #52 on: January 11, 2015, 08:19:31 am »
Love ya work Alex. That looks awesome.
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #53 on: January 11, 2015, 10:16:49 am »
That is an excellent resto/rescue Alex. I hope the little bloke appreciates what he has and treats it with the respect it deserves.
« Reply #54 on: January 11, 2015, 01:11:34 pm »
well done mate, top job ;)
Offline alexbrown64
« Reply #55 on: January 17, 2015, 07:10:09 pm »
Well, this project is finished.  I made some final adjustments today and now she starts first kick and runs like a beauty.  The boy loves it and will take it for its first ride soon.  I have taken the final pix of the old girl completed.  Hope to look after her and have it for many years to come.
I have installed an hour meter to keep track of the next 36 years.  Big thanks again to RedAlert Rod who did a great job on the tank and front guard.  Here she is...
Offline scottm
« Reply #56 on: January 17, 2015, 08:47:45 pm »
  A credit to you , well done , your young bloke has something built not bought
pre 84 thank you very much
Offline steve7406
« Reply #57 on: January 17, 2015, 09:18:26 pm »
Now that's a bloody nice little bike well done.
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Offline RED ALERT
« Reply #58 on: January 17, 2015, 11:07:50 pm »
Looks great Alex, a real credit to the effort you put into it. Hope to see it at a track soon, but one of those' shame to get it dirty' bikes right now  :)
« Reply #59 on: January 18, 2015, 10:11:31 am »
What can I say except EXCELLENT workmanship.
