Author Topic: Any MR250 owners out there?  (Read 3344 times)
Offline bazza
« on: September 24, 2014, 04:34:08 pm »
 Can you tell me if a 1976 MR250 Rear wheel is the same as the 1976 CR250 rear wheel?
Embrace patina
Offline mick25
  • Hunter valley NSW
Re: Any MR250 owners out there?
« Reply #1 on: September 24, 2014, 07:17:43 pm »
Both the rear hubs have the same part numbers if that helps bro.
Offline johnmcc
« Reply #2 on: September 25, 2014, 11:05:03 pm »
Yep I've got an mr250 . Restored back to original spec , will be used in selected vinduro's , when I finally do the last few bits . MR back wheel is the same as CR . Front wheel is the conical type hub , I think the same hub as XL motosport & MT , front brake cable is different to CR . Rear sprocket is dished , getting hard to get . There are some PBI ones around , but PBI now list them as NA .
Offline bazza
« Reply #3 on: October 03, 2014, 02:16:59 pm »
YES dished sprocket getting rear, have put Alloy spacer behind straight sprocket for now. Got good 76 XL350 rear rim (same part #) so have most bits now start the build.
Embrace patina
