Author Topic: Where to buy shims for carb needles?  (Read 5774 times)
« on: September 05, 2014, 10:21:19 am »
Would anyone have an idea on what shops would carry small washers suitable for shimming carb needles, TD Hatrick may have them but I would feel a bit stupid calling up to buy just a couple of little washers.  Maybe some local-type shop could have something?
Groove 3 is too lean and 4 is too rich  :-)
Re: Where to buy shims for carb needles?
« Reply #1 on: September 05, 2014, 10:33:36 am »
http://www.circlips.com.au/content.php?sec=distributors
most bearing supplies should have them
Simo63
« Reply #2 on: September 05, 2014, 10:53:12 am »
Never seen one that sensitive to adjustment John  :o
« Reply #3 on: September 05, 2014, 11:14:17 am »
Yeh my 2005 YZ125 had a carb design problem that Yamaha fixed on the '06 model, they reduced the number of venturi pilot outlets from 3 to 2 and ran a different needle.
Having the 144 kit fitted has made the problem a touch worse, a half mill shim will get it close enough until I stumble across a cheap '06 to '14 carb  :-)
« Reply #4 on: September 05, 2014, 11:15:47 am »
Thanks pokey, I have an electronics shop 'Jaycar' down the road, I'll try them first.
Offline OverTheHill
« Reply #5 on: September 05, 2014, 11:38:16 am »
just wondering if there may be another reason that one clip groove should make such a difference!!, maybe a very worn needle jet [emulsion tube] where the needle runs--& maybe a worn needle too [combo], or idle mixture set way too rich & overlapping further up [as in] richening up on a closed throttle into a corner then having to clear, or needing a leaner cutaway on the slide. Or is it a carb [not sure what type] with big steps for one clip step. Thin a 36 bing [bung] i use has fairly large steps compared to mikuni etc. Sorry, don't mean to try & poke holes in your ideas--just tossing my ideas around [or was that just tossing lol?] Cheers.
Start again, even had a strange problem 20 years ago in bucket racing where [big ports & holes everywhere] & it blubbered uncontrollably just at the point where it got on the power [big power from a 100 lol] was rich symptoms [but wasn't] some smart arse said double up the reads coz they're fluttering at that point in the revs & bugger me 'they were'--absolutely fixed it on the spot. Had an RT2 reed block & cut off housing welded into a mudbug cylinder at a great angle--another failure but went like hell, till it blew!!. Cheers.
« Last Edit: September 05, 2014, 11:40:20 am by OverTheHill »
Offline Mike52
  • 81 KTM 125 LC
« Reply #6 on: September 05, 2014, 12:09:00 pm »
KLR 650's use shims to adjust the needle.
« Reply #7 on: September 05, 2014, 12:38:45 pm »
Interesting, thanks.  I guess if Yamaha reduced the number of pilot outlets on the next model that maybe there's too much fuel at part throttle? (1/8th?), been going down on the pilot (from 40 to 30), going to try a 27.5 next, it still starts cold without the choke but bogs (lean stumble) on throttle part opening until been running a minute.
Changing the needle from groove from 4 (std) to 3 cleans up part throttle when it is warm, I'm just interested to see what 3.5 would be like.
« Reply #8 on: September 05, 2014, 01:24:49 pm »
I recently got a pack of shims from a ebay seller  in the USA. Has 0.25 ,0.5 & 0.75 shims. Is it a mikuni or keihin
« Reply #9 on: September 05, 2014, 01:53:35 pm »
05 YZ = Mikuni TMX.
« Reply #10 on: September 05, 2014, 01:54:11 pm »
« Reply #11 on: September 05, 2014, 03:14:18 pm »
You need a tmx-x off an rm 125 ;)
« Reply #12 on: September 05, 2014, 03:20:17 pm »
Only thing I have in the garage are VM36 round slides and a PJ36 off a CR125.  I'll live with it for a bit longer  :-)
« Reply #14 on: September 06, 2014, 07:56:46 am »
try filing the back of the slide on your richer setting to let a bit more air in? or is that not achievable with that carby??
