Quote from: Lozza on September 02, 2014, 07:20:17 amMost late model 125/250 ignitions can be adapted. Post 97 CR 250 has 12v output so you can run programmable ignitions. The ignition curves are what you should look at.Thanks Lozza!I'm thinking of replacing the PVL on my '83 CR480. The CR480 ignition is on the right side, where as all the CR500's are on the left. Would this cause a conflict because of rotation? The companies listed only offer CR500 replacements. Could an '80's KTM 500 replacement be adapted?
