Author Topic: 1989 CR125RK parts.  (Read 1388 times)
1989 CR125RK parts.
« on: August 30, 2014, 09:05:03 pm »
1. Frame (main frame only). Desperately needs a paint job, but appears to be a good clean frame, with no visible cracks and only one small dent in lower frame rails.
2. Swing arm. Seems good.
3. Linkages.
4. Shock, has rust on shaft.
5. Airbox. One mounting insert missing.
6. Seat. One mounting hook broken, very old and faded Technosel cover, foam seems good.
7. Triple clamps. One steering stop broken from lower clamp.
$130 the lot, will separate.
Pick up from Yass NSW or Belconnen ACT, or will post smaller items at your expense.
Picks when photobucket decides it is so.
Nathan. 04000 23847.
« Last Edit: August 31, 2014, 09:15:58 pm by Nathan S »
Re: 1989 CR125RK parts.
« Reply #1 on: August 31, 2014, 09:16:12 pm »
Bump for photos.
