Author Topic: RM 125 83/84/85 gearbox  (Read 2628 times)
Offline D project
« on: July 31, 2014, 10:54:57 pm »
Any one have a good gearbox or countershaft gear set to suit above?
Offline BAHNZY
Re: RM 125 83/84/85 gearbox
« Reply #1 on: August 01, 2014, 12:02:00 am »
Jase,
Just remember that the ratios are different on the bike you mentioned.
What particular model is it that you are looking for?
Rod
Rod (BAHNZY) Bahn
Offline D project
« Reply #2 on: August 03, 2014, 04:32:35 pm »
Rod, I didn't want to bug you for more parts as you've been a big help allready!
The gearbox in my 84 shat itself. I had an 83 bottom end which has the same gearset as the 84.
I did about three laps on that and then the second gear, which is a press fit on the shaft spun itself loose.
Is the 83 and 85 different ratios?
Offline BAHNZY
« Reply #3 on: August 03, 2014, 05:55:40 pm »
Not sure about 83 to 84, but there is a difference between 84 and 85, Im just not sure which gears off the top of my head. Have you got a pic of the gear that you need? Ill have a look and see whats in the box'o'bits.
Rod (BAHNZY) Bahn
Offline D project
« Reply #4 on: August 03, 2014, 06:38:45 pm »
Need the complete countershaft gearset. The end gear on mine has spun loose and is a press on/ interference fit? Pity coz it looked to be low hour and great condition :'(
