Author Topic: RM'ing an 81 PE  (Read 15240 times)
Re: RM'ing an 81 PE
« Reply #15 on: July 27, 2008, 01:58:30 pm »
alrighty, here's a couple of pics of what I started with and what it looks like at the moment.
Mechanically the bike was pretty damn good to start with, so apart from things like levers, throttle, and silencer, I'm mostly just doing a cosmetic rebuild. The silencer, which I pinched off my YZ project, is the one I made from an old grease gun, and it sounds fantastic.
Doc has very kindly supplied a 125 tank that I can clean up a bit and use, so I just need to find a 125 seat to match. The PE seat/tank combo don't really help when you're trying to get forward in corners. I ended up with my crack on the crack, if you know what I mean.
Also, thanks to OldFart for the advice on rear guards, the generic Cemoto one looks like it grew there.
« Last Edit: July 27, 2008, 02:00:58 pm by mainline »
Quicksilver
Re: RM'ing an 81 PE
« Reply #16 on: July 27, 2008, 03:51:15 pm »
That looks really good. Nicely done.
Doc
Re: RM'ing an 81 PE
« Reply #17 on: July 27, 2008, 04:38:35 pm »
Yeah, it looks really good Paul, congrats mate :)
love the lawn too by the way, another job well done ;) ;D
Re: RM'ing an 81 PE
« Reply #18 on: July 27, 2008, 06:39:41 pm »
thanks for noticing the lawn Doc  :)
I'll have to remember to put those backing panels in the ute, so I can drop them off one day.
Offline Wombat
  • Gold Coast hinterland
Re: RM'ing an 81 PE
« Reply #19 on: July 27, 2008, 07:30:23 pm »
Nice job mainline - it's looking like a bought one!
"Whadaya mean it's too loud?! It's a f*ckin' race bike!! That pipe makes it go louder - and look faster!!"
Offline holeshot buddy
  • sunshine coast qld
Re: RM'ing an 81 PE
« Reply #20 on: July 27, 2008, 09:30:28 pm »
shit thats lookin good  8)
knew i should have kept her  :'(
doesnt matter its gone to a good home ;D
follow me to first turn
Re: RM'ing an 81 PE
« Reply #21 on: July 28, 2008, 10:06:06 am »
at least it'll never get the ring revved out of it ;D
 Your mate was right though, it's a really nice bike to ride, and the new lower handlebars made a big difference.
Re: RM'ing an 81 PE
« Reply #22 on: July 28, 2008, 03:13:36 pm »
Put a thinner head gasket , and look at the rear shocks ( bit too soft ) - trim muffler  back to 50mm from  seat  bracket and remove the restrictor then reweld cone section back on .  ;)
Re: RM'ing an 81 PE
« Reply #23 on: July 28, 2008, 04:26:20 pm »
you'll have to explain grasshopper...
the headgasket I'm assuming will give higher compression?
the shocks seem to work ok at the speed I'm currently capable of travelling, but they're not adjustable so do I change to RM shocks or aftermarket if needed at some stage?
and the silencer is my rebuildable greasegun homemade job on loan from the YZ. It works so well though that I think I might make another. It's about 1/4 of the length of the original PE one.
Re: RM'ing an 81 PE
« Reply #24 on: July 28, 2008, 05:05:00 pm »
Thinner gasket gives more comp, and better performance all round .
The stock baffle works well , the trick was to remove the restrictor and shorten em up ...in there days
Next time you have the shocks off. machine extra groove's in the body @ 5mm centres
Re: RM'ing an 81 PE
« Reply #25 on: July 28, 2008, 05:18:58 pm »
does old mate at RAD do these sort of mods?
Re: RM'ing an 81 PE
« Reply #26 on: July 28, 2008, 05:26:19 pm »
yes
Offline crs-and-rms
  • heaven 23
Re: RM'ing an 81 PE
« Reply #27 on: July 28, 2008, 08:01:07 pm »
i thought i the 250 didnt have a restrictor plate in the pipe only in the sillencer its the 175 that has the restrictor in the pipe
Offline DJRacing
  • YZ125X
Re: RM'ing an 81 PE
« Reply #28 on: July 29, 2008, 10:24:40 pm »
TM Bills PE RM 175 1981 PE 175 with 1980 RM 125 tank & seat ugly aftermarket rear gaurd & fox shocks  :)
And his TS ER 185 TM 125 hybrid 1978 TS 185 with 1974 TM 125 tank & 1980 RM 125 seat , Tm 125 forks and wheels :)
« Last Edit: July 29, 2008, 10:28:10 pm by DJRacing »
Re: RM'ing an 81 PE
« Reply #29 on: July 30, 2008, 04:58:24 pm »
I might have to talk to Bill about how the tank fits, look like the mounting points are different from PE to Rm. Looks like it bolts into the same point as the exhaust bracket.
and now I'm wondering whether I just modify the PE seat a bit and leave the tank as is. I'm starting to like the chunky tank look :-\
