Author Topic: suzuki rm 125 79/80 barrell  (Read 2164 times)
Offline LeighW
« on: July 23, 2014, 05:51:38 pm »
hi all looking for a barrel to suit a rm 125 79/80 in good cond  cheers leigh
Offline rocketfrog
Re: suzuki rm 125 79/80 barrell
« Reply #1 on: July 24, 2014, 10:05:50 am »
I have a couple here Liegh, could do with a bore and over size.
Offline kitakitsune
« Reply #2 on: July 26, 2014, 06:10:49 pm »
G'day Rocketfrog
                           would you have a spare cylinder, I could bore 1mm to 55mm for the flat track charity day? If so, how much posted to allambie NSW 2100? My current cyl. has pulled the head studs out of the barrell. ( already helicoiled). I have a cyl enroute from the U.S. but condition and arrival time are not guaranteed. My phone is 0406008280.
Cheers Chris
Go no-where in your mind, and
you are now-here.
Offline Tomas
« Reply #3 on: July 26, 2014, 09:14:59 pm »
You can still save your cylinder. What you need is thread inserts. Much stronger than helicoils. Greg Ball did a cylinder for me that already had helicoils pulled out. Greg Ball, Kirrawee NSW,(02) 9521 8470. Hope that the cylinder that you geting from US does not suffer the same issue.
Offline kitakitsune
« Reply #4 on: July 27, 2014, 03:11:34 pm »
Thanks for the heads up Tomas. The tracker says my cyl arrived in Aus last friday. Just up to auspost now. Hopefully by wed I can make a decision.
Cheers Chris
you are now-here.
