Author Topic: What s the differences between MT and Cr125  (Read 15055 times)
Offline Natroy
Re: What s the differences between MT and Cr125
« Reply #15 on: July 31, 2014, 10:02:08 pm »
Until the MT 125/250, Honda only made four stroke trail bikes. Then again I can't remember a decent Honda two stroke (except for the cr's). The CR and MT are light year's apart.
« Reply #16 on: July 31, 2014, 10:29:19 pm »
If you want one of the little buggers sing out. I know a bloke who has one. J
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #17 on: August 01, 2014, 10:58:18 am »
The MT250 can be made into a fast bike with the help of CR barrel, head and carby. Mine goes just as good as a CR and I think the gear ratios are better spaced. I also put on the CR ignition (removes a lot of flywheel weight) and a NOS DG pipe. I also think there is less flex in the MT frame compared to the CR.
Offline OverTheHill
« Reply #18 on: August 01, 2014, 11:38:31 am »
i see some MT250 talk there--i have a CR250 points ignition system [minus coil/condenser under the tank]. Had an MT250 a couple of years ago, you'd laugh if you saw it when i found it lying out behind a disused dairy factory corroded to bits so of course the old 'you'll never get that going' said by someone, got me started. Ran perfect too without any cost & bolted it into an old yamy R5 frame as a test bed. went to a guy for a 'grass kart' in the end. We sold them new where i worked back then but get more exited about them now than then--sad that!!. Cheers.
Simo63
« Reply #19 on: August 01, 2014, 03:02:08 pm »
Whilst Honda specialised in 4 bangers, they made some decent 2 strokes such as the H100 and the MT250.  The only problem with the MT250 is that people unfairly compare it to the CR.  Of course it's not going to stack up against a CR but neither did the venerable XL250 Motorsport either  ::)  An unrealistic comparison in my mind and one you could repeat with just about any Japanese brand of bike back in the day ... the DT's vs the YZ's etc :)
« Reply #20 on: August 01, 2014, 07:56:31 pm »
"Of course it's not going to stack up against a CR " unfortunately Honda suggested it would... :D
« Reply #21 on: August 01, 2014, 09:17:32 pm »
Best LOOKING bike in the day,
 Compared with its trail bike peers and No that doesnt include MX bikes as it was never designed to be on a MX track ever. the MTs performed quite ok even if they  broke cases if you looked sideways at them and had points.
A CR also makes a pretty crappy trials bike so camparing them  someone will always be a loser.
 In 77 I had a TS250. mate had a Matador  and another a MT250 and another a motorsport.
 Straight drag open ground the MT had the goods off the start then I could run him down with with the TS, Bully was a few lengths back then the heavy motosport.
 In the forest where it was also designed to go it wasnt that good compared with The bully that had the torque and the TS that was just a good for the time trail bike . the MT rider didnt sweat as much as the guy doing weightlifting  exercises with the bucket of lead motorsport though.
It just wasnt the best and that didnt translate into sales  so honda went with its heritage and what was working at the sales office.. the Cr and the XL and if it was my back pocket i would  aswell.
 FWIW. its an okay bike just not the best and a bit fragile. Damn good looking though but not for everyone.
Offline Natroy
« Reply #22 on: August 02, 2014, 06:30:36 pm »
I had an MT 250 and of course you can't compare it to a CR. It couldn't even keep up with a RT or DT. I know, I tried several times.
They were the cheapest 250 in their day, $755.00 on the road from Motocross in Penrith.
« Reply #23 on: August 02, 2014, 06:37:17 pm »
in the words of someone famous (not sure who..??) " they are the best looking disappointment of a motorcycle known to man"
Offline chippy
  • how old is too old
« Reply #24 on: August 02, 2014, 09:49:13 pm »
This is my little MT125. A great looking bike, starts first or second kick every time.
Easy to ride but very heavy. A good one to have in the shed.
        Cheers Chippy.
« Reply #25 on: August 03, 2014, 08:29:56 am »
Here's my MT/CR250.....just how Honda should of / could of built the MT
« Reply #26 on: August 03, 2014, 08:42:45 am »
now youre talkin ;D
