Author Topic: hard to get bearings  (Read 3774 times)
« on: June 29, 2008, 02:09:43 pm »
I need some 25mm OD or 63/64” OD heim/spherical bearings/bushings.
I’ve tried the IKO catalogue and it seems all I can get is 22, 26 or 1 inch OD.
I don’t want to ream out eyelets to 26 or 1 inch OD.
Is my only option to make sleeves and use 22mm OD bearings?
its seeming like my preferred size of 25mm OD or 63/64” OD is non existant
YSS
Re: hard to get bearings
« Reply #1 on: June 29, 2008, 03:16:12 pm »
How many do you need ? Have 25 x 12  x 15 ID
« Last Edit: June 29, 2008, 03:21:04 pm by YSS »
« Reply #2 on: June 29, 2008, 03:26:21 pm »
they are a weird size i think 25mm will work but in all honesty i think they are 63/64
i need ID to be preferably 12mm but larger is fine.
width of outer race no wider than 17mm but can be narrower.
i need minimum of 4 but if they are are to get i think its worthwhile stocking up
« Last Edit: June 29, 2008, 03:29:46 pm by LWC3077 »
YSS
« Reply #3 on: June 29, 2008, 03:32:46 pm »
What Brand  and model of shocks are they for ?
« Reply #4 on: June 29, 2008, 03:35:09 pm »
Konis! ;D did they use metric or imperial??????
YSS
« Reply #5 on: June 29, 2008, 03:36:29 pm »
They should be 24.98 then .
« Reply #6 on: June 29, 2008, 03:44:43 pm »
well im pretty sure the bearings measure around 25.05-25.10
hang on ive got an old one in hand and with verniers now and im getting 25.03-25.05mm
i have to press the veriers together real hard to make them read exactly 25.00
i reckon 25 will do it as im not going to find 24.98 bearings
« Last Edit: June 29, 2008, 04:22:23 pm by LWC3077 »
YSS
« Reply #7 on: June 29, 2008, 04:13:25 pm »
Warm up the eylet and freeze the bearing , then it will fit nice.
« Reply #8 on: June 29, 2008, 04:32:47 pm »
ok YSS has some but i would be looking at around $380 for 4 :o. i just cant really afford that. i think my limit would be around $50-$60 each
any other ideas?
who else manufactures spherical bearings other than IKO?
maybe i can get some from USA a bit cheaper.
YSS
« Reply #9 on: June 29, 2008, 04:58:20 pm »
25 is an od size that was made only for one manufacturer . They paid for the setup .
YSS are 26 and cost less then a third. Just bore up the eylets to 26 and then your bearings are alot cheaper.  ( Or buy new shocks then the bearings are already init.)
« Reply #10 on: July 03, 2008, 08:36:57 pm »
Have you tried a  surplus bearing outlet         Try this #  07 3808 7494
        or     [email protected]     (off Moss ST  );D
« Last Edit: July 03, 2008, 08:41:12 pm by oldfart »
YSS
« Reply #11 on: July 03, 2008, 09:13:57 pm »
Found a source for 25 .OD . Available after september. Cost $42.00 each
