Author Topic: CR480 Carb Upgrades  (Read 41359 times)
Offline sa63
Re: CR480 Carb Upgrades
« Reply #45 on: November 14, 2014, 04:14:07 pm »
I tried the standard pipe- wow ! seems a lot more snappy than the PFR. No wonder they were putting a  flywheel weight on them back in the day. Just a work boot rap in the paddock though... too hot and dry to ride..
Will have to do a trackside compare sometime with both
Tahitian Red - where did you source your simons link + washers?
« Reply #46 on: November 14, 2014, 05:19:49 pm »
sa63 where you based?
Offline Momus
« Reply #47 on: November 14, 2014, 06:53:32 pm »
 Spot the mistake here, granted a 500 isn't about extracting the maximum
One mistake, if you have an 84, is the suggestion to use a plug mandrell as the turning fixture.
The finnies have an angled plug.
« Last Edit: November 14, 2014, 06:56:08 pm by Momus »
If you love it, lube it.
« Reply #48 on: November 14, 2014, 10:06:18 pm »
That's correct now you reminded me of it. Been a fair while but IIRC used the base gasket to close the squish up.
Offline Tahitian_Red
  • Mugen ME480
« Reply #49 on: November 15, 2014, 02:38:55 am »
Yes the 480's and '84 500 are bit harder to do than most heads.
« Last Edit: November 15, 2014, 06:28:10 am by Tahitian_Red »
The "Factory Novice"
California, USA
Offline sa63
« Reply #50 on: November 15, 2014, 08:36:24 am »
SEQ
