Author Topic: KX 500 ignitin timing  (Read 7321 times)
Offline subarumy98
« on: June 26, 2008, 05:46:48 am »
HI Guys
KX500 water pumper evo class, What is the std ignition timing ? About 14 degrees BTDC.
Some friend of mine are struggling, she coughs splutters and breaks kickstart shafts.
but no holeshot joy yet.
I have tried a few searches, but no detail info so far.
PS> They are tryig to Jerry-rig an ignition to work, as the stock Kawasaki items are in VMX heaven someplace.
T
Offline subarumy98
Re: KX 500 ignitin timing
« Reply #1 on: June 27, 2008, 08:18:05 pm »
HI Guys
How about 16 degrees BTDC - would that work ??
T
Offline holeshot buddy
  • sunshine coast qld
« Reply #2 on: July 09, 2008, 07:52:49 pm »
sorry took so long to respond didnt see the post :-[
timing is
13 degrees btdc ( or1.5mm btdc) ;D
follow me to first turn
squirtmoto
« Reply #3 on: July 09, 2008, 08:53:40 pm »
This might not be the problem but its a start
1. Check your flywheel magnets for cracks as this will send false signals to the CDI
2. The stator is identical to a Yamaha IT 465-490 so do a OHMS test to make sure it is the OEM item
3. If you do get it going check the timing marks on the flywheel and stator plate line up with a timing light then set the timing at 14Deg BTDC. when running the marks should line up. as the revs increase to aprox 4000, it will advance, then retard to almost TDC at 6500-7500 RPM
Confusing eh!!!!
Offline mxmaniac
« Reply #4 on: July 09, 2008, 10:07:37 pm »
Off the topic a little but am interested to know, What do the big 500's generally rev too before signing off?
Maico's, the only way to go.
« Reply #5 on: July 10, 2008, 09:35:10 pm »
NOT SURE I USUALLY JUST UPSHIFT ;D ;D
