Author Topic: Wanted Yamaha SR500 Ignitor Unit  (Read 5064 times)
Offline SON
« on: May 08, 2014, 09:36:13 pm »
Or if you know of someone that might
Offline asasin
Re: Wanted Yamaha SR500 Ignitor Unit
« Reply #2 on: May 09, 2014, 07:47:54 am »
  I am restoring a SC500 . It has a YZ 490 ignition on it , I have been told it is supposed to make them less light switch like and better power. Might be a option for you
If in doubt ,WIND IT OUT
Offline OverTheHill
« Reply #3 on: May 09, 2014, 08:50:46 am »
Hi, by memory--[used to work for a yam dealer a lifetime ago] SR500 Yams are 12volt cdi or tci so just saying be careful what you buy. If it's the original system it'll only have the trigger coil only down the bottom, i think it's sitting outboard of the flywheel activated by a raised strip on the flywheel. XT/TT250's are cdi & don't get me started on 'that'--they used to stuff the box & stay fully retarded [barely run--idled good lol], had one [still got it] guy bought to me with the exact symptoms--cdi box i said, so to prove a point before spending lots on a box i advanced the flywheel & did it up bloody tight minus the key which helped but didn't fix it and found [after head scratching] that the inlet cam lobe had all bit disappeared [i mean gonnne]. Went good after that lol. Sorry--getting off track again.
« Reply #4 on: May 09, 2014, 02:06:59 pm »
no sr500 have their own cdi charge and pulser coils and need no battery for sparks. they also have a 3 phrase alternator for running lights etc but that doesn't power up the ignition system ;)
Offline curly001
« Reply #5 on: May 09, 2014, 02:36:15 pm »
Son I have a spare CDI for a SR500.
Jim don't buy a hyperpak there crap ! Buy a CDI from marcus in England. I can send you his details.
« Reply #6 on: May 09, 2014, 04:07:15 pm »
i still run points have a pvl with added flywheel weight but still in the shipping box
jim
Offline OverTheHill
« Reply #7 on: May 09, 2014, 07:40:06 pm »
sorry, cocked that one up & should have 'google imaged' the stator first. Knew they were 12volt for lights & charging, real good big headlight too.
Offline OverTheHill
« Reply #8 on: May 09, 2014, 07:51:44 pm »
actually i know what got me thinking along those lines, the words 'ignitor unit' makes me think battery powered rather than stator coil powered for some reason, probably because i've had to replace a crook ignitor box on my old 'honda vigor' car.--anyway, back to me beer.
« Reply #9 on: May 10, 2014, 08:46:32 pm »
Honda;s had 12v powered up cdi's on e/start xl600rmg and 650 dominators,they had an inverter in them to step up the voltage from 12v dc to the voltage cdi systems run at.
