Author Topic: crankshaft balancing  (Read 3775 times)
Offline Tomas
« on: May 03, 2014, 03:59:53 pm »
Hello
Just would like to know if it is necessary to balance a crankshaft after it was modified and rebuild. The crankshaft in question is 1979 rm125 crank with 2000 rm 125 rod kit installed. New rod is touch heavier. What would be a simplest way to balance a crankshaft? Is it necessary to have piston installed when balancing?  I dont have any special tools etc.
Thank you for any ideas and help
Offline oldyzman
  • 250 two stroke!
Re: crankshaft balancing
« Reply #1 on: May 03, 2014, 04:24:24 pm »
Good Question,
I await a silver bullet simple answer as i am interested in this also....
« Reply #2 on: May 03, 2014, 07:22:05 pm »
there is a guy in qland who is on café husky and he has balanced cranks on a husky 250 and a 400 with good results, his forum name is Dukkman
« Last Edit: May 04, 2014, 08:24:00 am by 80-85 husky »
Offline Brian Watson
  • First Penton in OZ
« Reply #3 on: May 03, 2014, 07:44:00 pm »
or...of course..the best guy in the land....Frank Stanborough...Franks Cranks...used to be Graeme Smythe's Kwaka mech..very clever guy...
« Reply #4 on: May 03, 2014, 09:08:40 pm »
Hello
Depends on how many grams "a touch" is ? There is no 'simple' way to balance a single cylinder crank as the balance factor is a % of reciprocating over rotating masses. The only simple answer is to try it. If it shakes your fillings out or the handlebars feel like the size of 2inch water pipe you will have to rebalance the crank
Offline Tomas
« Reply #5 on: May 03, 2014, 09:47:00 pm »
Just find some informations about how is it  done here if anyone is interested. http://www.xs650.org.au/Club%20Racer%20Stuff/Club%20Racer%202013.htm (scroll down)  It is not that hard at the end.
Offline Michael Moore
    • Euro Spares
« Reply #6 on: May 04, 2014, 02:15:15 am »
This article by Tony Foale will help you understand what is going on:
http://www.tonyfoale.com/Articles/EngineBalance/EngineBalance.pdf
Tony also wrote a little program for single cylinder balance factors that you can download here:
http://tonyfoale.com/progs/BF.exe
cheers,
Michael
