Author Topic: TM 125 ignition woes  (Read 10378 times)
Offline ty4
Re: TM 125 ignition woes
« Reply #15 on: March 08, 2014, 09:04:41 pm »
seemed to have fixed the problem...loosened the trigger coil and shimmed it to create an even air gap..no more kick back
after so much kicking the kickstarter shaft is now slipping internaly so i cant get a decent throw of the kicker....AAARRRGH  ;D ;D ;D
tony
Offline brent j
« Reply #16 on: March 08, 2014, 09:19:43 pm »
Your next adventure (?) is to find out if it's the pawl in the ratchet, they do wear, or a broken kick start idler gear.
I've broken two kick start idler gears from kick backs
If it's just the pawl you can bump start it.
If it's a few teeth off the kick start idler gear you can still bump start it BUT there's a very good chance the idler gear may end up tooth to tooth with the clutch gear or the kick start gear in which case something has to give.
I'd expect to see a broken centre case.
If you are still running the oil injection you may lose drive to the oil pump as it runs through these gears
If it was mine, and this is what I did, I'd be splitting the cases to check and replace the kick start idler gear and kick start pawl while it's apart
Offline Doc
« Reply #17 on: March 08, 2014, 09:22:09 pm »
at least it's only a cheap part to replace if it's just the pawls ;D
never mind the pain in the arse job it is  ::)
« Last Edit: March 08, 2014, 09:23:56 pm by Doc »
Offline brent j
« Reply #18 on: March 08, 2014, 10:18:14 pm »
Even the kick start idler gear is only about $55, or the last one I got was.
I think it's worth replacing both while it's apart
And pain in the arse job is right eh Doc?
Offline ty4
« Reply #19 on: March 20, 2014, 06:25:16 pm »
just fix the kicker i said
leave it alone i said
here we go again  ::)
Offline brent j
« Reply #20 on: March 20, 2014, 06:28:49 pm »
What did you find?
Offline ty4
« Reply #21 on: March 20, 2014, 06:40:48 pm »
 a jigsaw puzzle because i seperated the cases from the right hand side and a very round kicker pawl
Offline Doc
« Reply #22 on: March 20, 2014, 06:50:26 pm »
I like it!!  ;D
« Reply #23 on: March 22, 2014, 09:33:40 am »
;) :) :-X
« Reply #24 on: March 22, 2014, 10:02:49 am »
you will have to reco that shocker to match the rest! 8) ;D
Offline Nipper
« Reply #25 on: March 22, 2014, 10:30:23 am »
Nice work ty !!
Offline ty4
« Reply #26 on: March 26, 2014, 06:53:27 pm »
a change of colour
tony
