Author Topic: Fuel:oil mixture for RM 125 B  (Read 49902 times)
Offline davidmc
Re: Fuel:oil mixture for RM 125 B
« Reply #15 on: February 03, 2014, 05:08:16 pm »
40 to 1 on Motul is chancing your luck,
I would not recommend any leaner than 30 to 1 with a 125cc screamer,
sorry Son
Offline Ted
« Reply #16 on: February 03, 2014, 05:17:38 pm »
sorry Son
Exactly.
Ken, if you can hold this thing pinned everywhere, go to a 9 plug as well. If you can't use a 8
81 YZ 465 H   77 RM 125 B
Offline Ken 737
« Reply #17 on: February 03, 2014, 05:42:55 pm »
An 8 it is Ted :)
Ken
Suzuki fan - TM and RM
Love my IT too ????
Offline Ted
« Reply #18 on: February 03, 2014, 06:18:59 pm »
I'm hearing ya ;D
Offline Ted
« Reply #19 on: February 03, 2014, 06:25:21 pm »
Davy Crocket( Qld ) on here sells the 927 Maxima. He's a good guy, just doesn't have many friends 8)
If you can't get it for whatever reason ring these guys. They import it. Ohlins 0395809465
Offline searbs
  • Victoria
« Reply #20 on: February 03, 2014, 07:48:19 pm »
Retro Rocket, this is one of the best threads I have read here:
Dispelling the mystery between BR MC1 and other 2T oils ,by shortshifter
25:1, for me in bikes chainsaws brushcutters and leafblowers for me seems to work, more oil means more cooling,
I don't race VMX though,
Searbs
« Reply #21 on: February 03, 2014, 08:38:37 pm »
I disagree, more oil means hotter running as there is less fuel per charge. im running 80:1 and up to 100: 1 in a husky 400 and its been great, jetted nice and lean, it runs as smooth as a baby's bum down low, pulls off the bottom like the Scottish flyer and revs like a 125b (no thanks to ol mate with the porting tool!!) so I would use a full synthetic at 40:1 and ease out to 50:1 I use motorex...) no splooging, easy starting and cooler running.....
its a constant argument but im happy using less of a very high quality oil (2 years and so far so good) also runs my whipper snipper, blower vac, chain saw and Kato 300 (4 years and no drama)
Offline Ted
« Reply #22 on: February 03, 2014, 09:20:01 pm »
So why do go karts run at 16:1
Simple answer.....because they rev to the moon
« Reply #23 on: February 03, 2014, 09:40:30 pm »
KTM recommend 50:1 in all their 2 strokes and they offer full warranty! I can't see a problem running Motul or Motorex at 40:1 in a RM125b.
Offline mudguard
« Reply #24 on: February 03, 2014, 10:18:42 pm »
Just seized my 83 YZ125 last weekend, after replacing the cylinder & piston last July, as piston nipped up then. NEVER using MOTUL 800 again. Have always been mixing at 32:1 and has always been hard to start, if not started after sitting for more than a week. ( Even with fresh fuel mix ). Usually have to take the bowl off the carby, take out the pilot jet, clear the blockage from the fuel/oil, then it will start.
Took the cylinder & piston to get rebored and old mate gave me some good info. Motul oil at 32:1 is not lubricating my cylinder, the inside of my piston is dry but should have an oily film coating it. Take mixture back to 25:1 and re-jet to suit, motor should have more power, run cooler and last longer as well. (Going by his years of engine rebuilding knowledge)
Sure the modern oils say can be used at 32:1, 50:1 or higher, but the fine print also says to Refer to the Vehicle Manufacturers Recommendations.
« Last Edit: February 03, 2014, 10:20:14 pm by mudguard »
« Reply #25 on: February 03, 2014, 10:23:48 pm »
Not correct engines conduct heat to the cylinder wall via the rings the better the ring/bore seal the better the heat is wicked away. Oil is still the best for that.  Unless you put your bike on a dyno or give it to a GP level rider there is no objective way to determine what is "better" Gordon Jennings did all of this back in the 70's and we have yet to see anyone do the same tests with low oil ratios.More oil more power engine runs cooler.
"Spooge" out the exhaust is a symptom of  jetting and ignition.
« Reply #26 on: February 03, 2014, 10:59:46 pm »
I've been using Motul 800 at 40:1 in my vintage race bikes for 10 years with none of the problems you've  had and I worked in the Husqvarna race team for several years where we used Motul 800 at 40:1 in the National race bikes with never a problem..
You've got other issues.. It's not the oil.
« Reply #27 on: February 04, 2014, 09:40:19 am »
ive yet to see a oil related seize, there is always a mechanical reason...generally an air leak causing a hot spot or poor jetting in the midrange.
« Reply #28 on: February 04, 2014, 11:06:49 am »
Yep or even an ignition problem. Oils are very good these days, we're not back in the 70's
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #29 on: February 04, 2014, 01:50:11 pm »
Too much oil can result in seizure as well. The unburnt oil glazes up the ring landings and piston walls, causing premature wear. Personally, I have all my 2 smokers (including whipper snipper) on Motul 800 at 40:1 for years,  and I have never had a seizure. I ran my 74 Elsinore at 40:1 and the piston and rings lasted 2 entire seasons without any signs of scuffing. Shite, my whipper snipper is at least 10 years old and it revs to the moon and back without any dramas so I don't see why a 125 would require more oil than any other 2 stroke.
