Author Topic: YZ125C front brake.  (Read 1554 times)
YZ125C front brake.
« on: June 11, 2008, 10:18:05 pm »
Basically, I'm after the front brake backing plate from any YZ or MX that came with non-leading axle forks and a conical front hub - they're all pretty much the same.
IT400C probably also uses the same sort of brake.
Doesn't need to be pristine, just useable.
You know the score: Will pay cash, swap bits or whatever.
I've got an uber-rare YZ-D front brake which still has an unmolested cable hole to swap, if that helps ;).
04000 23847
