Author Topic: Race Tech Emulators and YSS PD valves  (Read 52674 times)
Offline Monoshock Doc
  • Monoshock and later dirt suspension rebuilds.
Re: Race Tech Emulators and YSS PD valves
« Reply #45 on: January 23, 2017, 08:02:14 am »
We've only done suspension the past few years Walter but nice try.
If you need shocks  for that Maico, I can get you Race Tech or YSS (these at a really cheap price) for you.
I had no idea Thailand was part of Australia!?
« Last Edit: January 23, 2017, 08:07:14 am by Monoshock Doc »
Offline supermotomc
  • SWM ktm, dealer mechanic 1977-1995
« Reply #46 on: January 23, 2017, 09:00:36 am »
what shock do yo want what to fit what year ?
Offline Momus
« Reply #47 on: January 23, 2017, 11:25:16 am »
I have the compression valves on a few of my bikes. Even without extensive testing adjusting they make a positive diference. The 2 sets of Racetech units, in a 84 CR500 and a RM 370 are from brass, strong and well finished - chamfered and deburred and with alternate springs. I also have YSS set. These are made fom anodised aluminium and are thin section and look to be a bit short on mecanical strength. Service  was a bit ordinairy. I was sent the wrong items but refused a return. I ended up using them on forks they were intended for and if installed according to instructions would have reduced the fork travel, hammered the valves as the spring coil bound and very likely with the damper rod mods required, pulled off on full extension.
If you love it, lube it.
Offline Wasp
  • Your Suspension Solution since 1989
    • Suspensionshop
« Reply #48 on: January 23, 2017, 12:51:30 pm »
You must have used the black ones Momus . I know of the downfalls on them , thats why they got replaced with the brass ones in 2009 . I am doing a new series right now with a couple of improvements .
VMX shocks , We don't just sell them - I design and produce them individually for you since 1989.
