Author Topic: Tool need to pull apart fork legs  (Read 2385 times)
Offline kenny5000
« on: December 03, 2013, 09:51:10 pm »
I am pulling my fork legs apart to replace the seals and need to replicate the holding key pictured below. I plan to do this by flattening a piece of steel tube the cutting a notch/cutout in it to hold the damping spindle. Has anyone made a tool to do this and if so what would the width of the cutout have to be?
Offline Gippslander
Re: Tool need to pull apart fork legs
« Reply #1 on: December 03, 2013, 10:10:45 pm »
Have done this job a few times and never needed the special tool, just undo the bottom bolt, I know that some use an impact gun on a low torque setting,  I suppose that one day I will run into one that will not come apart without the special tool to hold the damper rod still but has not happened yet.
Offline grouty
« Reply #2 on: December 04, 2013, 02:04:35 am »
You can easily do the job without the tool providing the forks are still fitted to the bike.
The link will take you to the tool I made a while ago ..... in a hurry !
http://www.cafehusky.com/threads/35mm-damper-rod-tool-by-bodgit-scarper.25891/#post-232945
Thumpers Rule !
Offline kenny5000
« Reply #3 on: December 04, 2013, 07:41:46 am »
Thanks, just what I was after!! :D
