Author Topic: rm 125 n  (Read 3681 times)
Offline LeighW
rm 125 n
« on: November 13, 2013, 05:36:31 pm »
just picked up a 125n going to change the piston and rings have seen some kits two ring some one ring whichis original or which is the best to use cheers leigh
Offline oldyzman
  • 250 two stroke!
Re: rm 125 n
« Reply #1 on: November 13, 2013, 06:07:05 pm »
I would use the two ring unless you want 11/10th's out of the bike. will last longer between rebuilds with two
Simo63
Re: rm 125 n
« Reply #3 on: November 14, 2013, 02:17:09 am »
I have a brand new genuine piston kit in the shed for an RM125N that I bought back in the day and never used.  It's a 2 ring setup and I would run with that to be honest.
Offline LeighW
Re: rm 125 n
« Reply #4 on: November 14, 2013, 05:45:13 pm »
might take you up on that simo its coming down from qld in a week or so once iv got the head off seen what oversize it is il pm you cheers leigh
Re: rm 125 n
« Reply #5 on: November 14, 2013, 09:36:29 pm »
Second rings are for soft cocks  ;D
Offline oldyzman
  • 250 two stroke!
Re: rm 125 n
« Reply #6 on: November 14, 2013, 09:42:21 pm »
I'm so hard even if its a two ring piston, i take the lower on off! LOL :-)
Brett
Re: rm 125 n
« Reply #7 on: November 14, 2013, 09:59:18 pm »
The lower cast iron ring on the on the DT1 from Hell used to snag the exhaust port on the Warren Willing ported barrel and break so I left the bottom ring out and never had another problem.
