Author Topic: Taking the piss  (Read 16905 times)
Taking the piss
« on: November 07, 2013, 06:21:20 pm »
Shelf wear my arse ....... water damage would be more appropriate.
This sort of stuff gets under my skin, when they blatantly wrongly describe an item.
http://www.ebay.com.au/itm/NOS-Suzuki-OEM-Piston-0-25mm-PE250-RM250-RS250-12110-40601-/121185110962?pt=Motorcycles_Parts_Accessories&hash=item1c37320bb2
Offline oldyzman
  • 250 two stroke!
Re: Taking the piss
« Reply #1 on: November 07, 2013, 07:35:43 pm »
That is useless, OK if it was some Works thing then maybe could be salvaged somehow.
 I think i have one for sale... maybe kit...
Offline SlideRulz
  • Not anti social just anti idiot.
Re: Taking the piss
« Reply #2 on: November 07, 2013, 07:56:01 pm »
I have a shelf in my workshop that I've managed to headbutt more often than I really should've.
Unless it's an item like a tank or side panel that has been moved around over the years, yes, it's a crap description.
Re: Taking the piss
« Reply #3 on: November 07, 2013, 08:14:34 pm »
Walter .... put your glasses on old mate and look at pic 4.   ::)
There is no way I would put that piece of crud in any of my bikes.
maxvmx
Re: Taking the piss
« Reply #4 on: November 07, 2013, 09:12:07 pm »
Don'r bid - easy!
Offline NSR
  • Sunshine Coast
Re: Taking the piss
« Reply #5 on: November 07, 2013, 09:14:49 pm »
This piston looked the same.  This is how it looks after Greg gave it the hydroblast treatment.
Would you put it in a motor?  I would like to know because these are rare.
« Last Edit: November 07, 2013, 09:21:09 pm by NSR »
The Swvm though the tree's! http://youtu.be/4h6BbasT16I
Metalink Conondale vinduro sprint. May 19/20 2018
www.metalink.net.au  Bike trailers & Canopies
Offline oldyzman
  • 250 two stroke!
Re: Taking the piss
« Reply #6 on: November 07, 2013, 09:29:33 pm »
Whats it for NSR
Re: Taking the piss
« Reply #7 on: November 07, 2013, 09:30:37 pm »
You make your choice and you try your luck.
I spent a lot of my youth and early adulthood putting together motors with highly questionable parts - sometimes it worked well, sometimes it just worked, sometimes it didn't work at all... But it did give me a pretty solid understanding of what really matters, compared to what makes people feel good.
If I owned NSR's piston, I'd prefer not to use it - but if it is hard to get a better one, then I'd fit it and wouldn't have a moment's worry about it causing me any problems.
Offline oldyzman
  • 250 two stroke!
Re: Taking the piss
« Reply #8 on: November 07, 2013, 09:34:26 pm »
Who replaces small end bearing every top end rebuild?
Offline NSR
  • Sunshine Coast
Re: Taking the piss
« Reply #9 on: November 07, 2013, 09:46:29 pm »
Whats it for NSR
It's a 175 SWM Rotax piston.  So a it is pretty tough piece, with a thick single ring. The 175 pistons are becoming harder to get.
Re: Taking the piss
« Reply #10 on: November 07, 2013, 09:50:51 pm »
Noel .... ring landings look sus along with skirt area .  I would say no don't use it.
Offline Doc
Re: Taking the piss
« Reply #11 on: November 07, 2013, 09:52:07 pm »
I'm a self confessed tin arse but even still I would not use either piston pictured above. Small end bearings and pin I replace whenever I replace the rings. Probably not necessary but it's cheap insurance and peace of mind. In 35 odd years have 'never' had a top end detonate ;)
Offline NSR
  • Sunshine Coast
Re: Taking the piss
« Reply #12 on: November 07, 2013, 10:35:51 pm »
This is it with the ring on it.  The ring grove is my concern.  Although with the ring on it does not look to bad.  I will still be trying to buy a better one.
Re: Taking the piss
« Reply #13 on: November 07, 2013, 10:43:55 pm »
The ring is still properly supported over the vast majority of its circumference.
What do you expect to be the problem?
Offline oldyzman
  • 250 two stroke!
Re: Taking the piss
« Reply #14 on: November 07, 2013, 10:47:06 pm »
If it fails it could make the whole thing FUBAR...
