Author Topic: YZ400D axle stuck in fork leg - how to get it out?  (Read 4339 times)
Offline mboddy
  • Canberra
« on: June 01, 2008, 12:19:34 pm »
The axle, wheel and one fork leg won't come apart.
Have tried soaking in wd40.
Can I get them apart without damaging anything?
If I have to destroy the axle are they easy to come by?
Vinduro Penrite Team
Offline gorby
Re: YZ400D axle stuck in fork leg - how to get it out?
« Reply #1 on: June 01, 2008, 12:45:57 pm »
when this happens it usually is the spacer between the wheelbearings that rusts to the axle.or the brake backing plate.
if you have the axle nut off and one fork leg then you may be able to heat the hub with a heat gun and whack the hub with a piece of wood to try and force the wheel off leaving the middle spacer and one wheel bearing still on the axle which can the be removed by heating with an oxy set.
If you have access to a large press,then you could slide the fork/wheel assy out of the clamps and press the axle out.
Offline mboddy
  • Canberra
« Reply #2 on: June 01, 2008, 04:34:43 pm »
It is worse that that. The axle is threaded into the fork leg. The axle threads are stuck in the fork legs threads.
Offline crs-and-rms
  • heaven 23
« Reply #3 on: June 01, 2008, 05:05:11 pm »
id soak it a bit longer might save the threads ive soaked parts that wouldnt move for weeks some times and they have come apart
Offline 490 tez
« Reply #4 on: June 01, 2008, 05:21:00 pm »
i have used a wurths product called rolst off and rolst off ice the ice is a little better i think if it still wont budge try heat and let it cool naturaly and do this a few times then when it is cool try to move it again allso when it moves if it gets tight wind it back in spray with your wd40 and wind out agin keep this up till it comes out
big bore two strokes rock!!!!!!!!
Offline pmc57
« Reply #5 on: June 01, 2008, 05:27:00 pm »
Looks to me like a little bit of heat may be the answer. Gently heat the fork leg with a torch around the lug where the thread is. With aluminium having a higher coefficient of expansion than steel, the corrosive bond will let go. After the heat is applied try and break the bond by trying to turn the axle, once it breaks loose, apply some WD40 or similar and work the axle until she starts to rotate and unscrew.
Offline caps 999
« Reply #6 on: June 01, 2008, 06:54:34 pm »
go to your nearest rece plumbing store and buy a tin of nut cracker its like 3x strenght wd40 and its worked on many of my projects and it works but its $55 a tin  :o
MUGEN power
Offline holeshot buddy
  • sunshine coast qld
« Reply #7 on: June 01, 2008, 09:03:44 pm »
get a black texta and mark around fork leg
around thread :o
heat up with oxy till texta mark disapears
that will be right temp 8)
then it should unscrew ;D
follow me to first turn
