Author Topic: RM125T ignition issue  (Read 9077 times)
Re: RM125T ignition issue
« Reply #15 on: October 09, 2013, 02:04:44 pm »
hi DOC I had the same issue the other way around  in my 77 125 b , it turns out that there are two stators with slightly different part numbers etc they look identical but as you have said run 180 degrees out of sync. it makes no difference in running only to the position of the wiring in the mag cover.
yep thats what Im saying ;) :)
