Author Topic: Phantom mikuni jetting specs  (Read 4441 times)
Offline xel93
« on: October 08, 2013, 09:24:04 pm »
G'day  does anyone know what a good starting point is for jetting a 36mm Mikiuni on a 74 Ossa Phantom?  It is currently on a 330 main and blubbers away
thanks Lex
Offline VMX60
Re: Phantom mikuni jetting specs
« Reply #1 on: October 08, 2013, 10:43:36 pm »
Lex
What are you running needle and needle jet ???
Best specs for my Phantom std porting and pipe
 98 fuel 32 to 1 ratio TTS castrol
36 Mikuni
310 main
40 pilot
Q0 needle jet
6F22 needle  middle clip
O2 air jet
Have also used 6F5 double taper needle with good results
Cheers   :)
Offline 09.0
« Reply #2 on: October 09, 2013, 06:32:35 am »
Do you have to run different intake and airbox boot?
Offline xel93
« Reply #3 on: October 09, 2013, 08:35:27 am »
Thanks very much VMX60!
I think it is the std intake there is one I layer of tape around the end of the carby to take up any gap when pushed into the inlet rubber.  It is a very neat fit and looks secure even before the clamp is tightened.  Not sure about the air box boot by looks original.
