Author Topic: shed cleanout version 3.0  (Read 8598 times)
Offline ty4
Re: shed cleanout version 3.0
« Reply #15 on: September 21, 2013, 03:04:08 pm »
still have them Alec
Offline crs-and-rms
  • heaven 23
« Reply #16 on: September 21, 2013, 03:15:24 pm »
i will take them both pm sent
Offline ty4
« Reply #17 on: July 19, 2014, 06:00:36 pm »
time to clean out some more...all below are NOS
MX 125 gear selector shaft
crank drive gear
2x 0.50 up pistons
1x 0.50 ring
1x 0.25 ring
fork seals..parts plus brand
$100 plus postage
DT 125...175 A/B clutch basket   $50
DT 125 E clutch shaft    2a6-17411-00   $20
DT 125 A/B/C  kicker shaft  $10
DT 175 A/B/C Lighting coil   $20
DT 360 Carb boot..cork oil tank seal  (5) ..rear brake arm (2)  $50
DT 400 D     0.50 up piston and rings  $40
DT1 repro fuel cap    $40
  all plus postage
AT1    idler gear x 4.......2x clutch pinion....2x front brake arms   $20
YZ 125 D air box drain nipple   $10
YZ 80 L/N  clutch pressure plate...push rod     $20
YZ 250 N     0.25 rings...rear shock rebuild kit...reed valve stops    $100
YZ 125 S   top of head radiator hose...bump stop...rear of tank mounting rubber    $80
TT 600 ....mx 400 B     Clutch springs      $40
TT600 L/N head studs   $30
TT 600 RE 96/99     swingarm saver  $50
TT 500 C inlet manifold  and rear brake rod    $60
XT 500 cush drive circlip   $10
honda xr/xl 350  DID cam chain      $40
kwacka F11  sprocket cover with nylon ? worm gear   $30
all above are plus postage
tony
