Author Topic: 77 Husky Barrel  (Read 8463 times)
77 Husky Barrel
« on: August 04, 2013, 07:22:08 am »
OK all you Husky techno's, is there much difference between a 77 Husky barrel and a 74 Mag Husky barrel and would the 77 be legal on a 74 for pre75 ?. While I'm at it, did Thor make an alloy arm same as there common looking arm to suit the same bike? I just want to clear up a few points before it drags on....you know....he said, she said, they said......
Offline Moto
Re: 77 Husky Barrel
« Reply #1 on: August 04, 2013, 09:08:11 pm »
Correct me if I am wrong,but I think that as long as it looks identical on the outside as the 74 barrel the 77 is ok.
Re: 77 Husky Barrel
« Reply #2 on: August 06, 2013, 10:29:35 am »
Where's the guru's....Husky Pete?.....Shoey?.....would be nice to know.
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: 77 Husky Barrel
« Reply #3 on: August 06, 2013, 10:44:28 am »
Hmmm...
this sounds familiar...
"flat bickie"
Offline Brian Watson
  • First Penton in OZ
Re: 77 Husky Barrel
« Reply #4 on: August 06, 2013, 11:02:38 am »
Externally there is nothing to note between the 74 Mag and 75/6/7 cylinder..
Simo63
Re: 77 Husky Barrel
« Reply #5 on: August 06, 2013, 11:05:46 am »
What about internally??
But I guess the real issue would be the date of manufacture, not the appearance?  Unless of course the parts come from a recognised follow on model.
« Last Edit: August 06, 2013, 11:17:45 am by Simo63 »
Offline Bamford#69
Re: 77 Husky Barrel
« Reply #6 on: August 06, 2013, 11:34:44 am »
Hi,
74 Mag head is straight cut , but will fit others, 75 76 77 is radial (sunburst) finned, check the engine #s
74 heads are very very hard to source , if anyone has a spare I know someone who wants to fit one asap,
Re: 77 Husky Barrel
« Reply #7 on: August 06, 2013, 11:41:53 am »
Internally doesn't matter Simo as you can port to your hearts content. Thanks Watto. Swingarm is out, owner did some research, they where not available in that configuration in 74. Cheers.
Re: 77 Husky Barrel
« Reply #8 on: August 06, 2013, 12:00:23 pm »
You can use a Boyd and Stellings alloy swingarm Joanie.....Husky Pete's got one on his new pre 75 Mag.  They're one of the few legal alloy swingarms for pre 75. They're actually legal for pre 70 in some cases ;).
« Last Edit: August 06, 2013, 12:02:05 pm by firko »
Offline HuskyPete
  • Huskys Only, maybe a CCM
Re: 77 Husky Barrel
« Reply #9 on: August 06, 2013, 03:14:02 pm »
As Firko has said, the only swingarms are alloy Boyd and Stelling and the Steel ProFab swing arms, i have the ProFab (thanks to Dave Tanner) on my 74 Mag 250 and the Boyd and Stelling on my 74 400, they are pretty rare .
Boyd & Stelling arm
I doubt the radial heads are legal as they came out on the 75 bikes.
Micheal i have a straight fin Mag 250 head if you need it $200 plus postage.
74, 75, 76, 77 barrels are externally the same, the porting is pretty much the same on all of them as Moto and Watto has posted already.
Pete
« Last Edit: August 06, 2013, 04:29:44 pm by HuskyPete »
Re: 77 Husky Barrel
« Reply #10 on: August 06, 2013, 03:46:36 pm »
Thanks Pete. They are cool bikes.
Re: 77 Husky Barrel
« Reply #11 on: August 08, 2013, 03:30:17 pm »
Not to under cut Pete,, but a 250 head from 1972, 1973 and 1974 are the same..tho in 1974 the fins were cut off the left side for the pipe... any amount of that era heads on eBay that only need some trimming...
Offline euro bikes
Re: 77 Husky Barrel
« Reply #12 on: August 18, 2013, 05:10:08 pm »
So dose this bike have a 6 speed box and is this legal here(australia)
