Author Topic: 1979 KX125 forks  (Read 3248 times)
Offline TonkaF1
1979 KX125 forks
« on: July 10, 2013, 09:40:05 am »
Hi there. I'm chasing a set of forks for my KX125. The KX forks that I got with the bike are off a 250 and are 3mm too big to go into the correct triple clamps. If anyone can help out, please call me on 0408911854. Thanks. Dave
The older I get, the faster I was. Current Bikes-78KX125,78KX250,79KX125,79KX250,83CR125
Re: 1979 KX125 forks
« Reply #1 on: July 10, 2013, 10:33:11 am »
The forks on the 125 are 38mm yeh?
TM BILL
« Reply #2 on: July 10, 2013, 11:21:35 am »
36mm
Offline TonkaF1
« Reply #3 on: July 10, 2013, 11:59:41 am »
Yeah, it's a big long story. The bike came with KDX forks and wheel fitted and a spare pair of KX forks. I got what I believe to be 79 KX 125 triple clamps(35.5mm), but the fork legs are the same size as my 250 forks (38.0mm). Plan A is to try and get the correct forks, if not, I will see if the 250 triple clamps and forks will fit, without it ending up as a Gumtree special.
« Reply #4 on: July 10, 2013, 02:22:27 pm »
Maybe something to keep in mind, I swapped my 79 KX250 triple clamps for '80 model KX250 or KX420, they bolted straight in, they have 10mm less offset, reducing the offset from 35mm to 25mm (10mm is a heap!!) giving more trail, the bike steers heaps better now.  Modern bikes are running about 20mm offset but with much steeper head angle.
« Last Edit: July 10, 2013, 02:25:06 pm by John Orchard »
Offline Vintmxman
« Reply #5 on: July 10, 2013, 09:31:07 pm »
I have a set of forks with clamps off of a 1978 KX 125 A4 , if your interested....
