Author Topic: RT-2MX/YZ360A Hybrid  (Read 39542 times)
Re: RT-2MX/YZ360A Hybrid
« Reply #60 on: September 19, 2013, 03:40:22 pm »
YZB went back to steel pins and have seen some A with the steel too but most are the ally.
I have a GYT piston port barrell and from what i can tell the hole thing is cast around a steel insert which includes all the ports, transfers and so on, so you cant just sleeve it, unless it was bore to take a steel inside steel simple liner.
ITS basically a complete barrell but with ally fins cast over it..... its only yammy can i have seen like it ( but then i dont get out much )
« Last Edit: September 19, 2013, 03:42:37 pm by Freakshow »
« Reply #61 on: September 19, 2013, 07:01:18 pm »
My RT1MX is a iron cylinder 2mm over . Its the only RT\DT 1 mx part I own . Iain
« Reply #62 on: September 19, 2013, 09:37:52 pm »
What do you mean by steel pins Freaky?
Offline Tahitian_Red
  • Mugen ME480
« Reply #63 on: September 20, 2013, 01:06:41 am »
He means the stem.
That thingy that the steering head bearings go on.  ;D
The "Factory Novice"
California, USA
Offline farmpro
« Reply #64 on: September 20, 2013, 11:30:18 am »
The steering stems on the YZA's here in the US were aluminum and bent fairly easily by most fast pro's.They were usually replaced by steel ones from DT/RT2MX's or MX250/360's or SC500's.They were press fit.
« Reply #65 on: September 20, 2013, 12:04:41 pm »
Yeah, it makes sense now.. from time to time I have a bit of trouble with Freak Speak ;D
« Reply #66 on: September 20, 2013, 12:57:35 pm »
NO probs.
Offline OverTheHill
« Reply #67 on: September 20, 2013, 09:25:18 pm »
Yeah, steering stems--God i remember my Elsinore CR250M ended up bending the steering stem from landing hard on jumps. Put a dogs leg in it after a lot of use so turned it half a turn & it slowly did it again so made a stem out of an old Yamy Landscout fork leg. Practiced my thread cutting till i got it right [didn't really know what i was doing but]. Think that was the one that i was trying suspension tricks on & moved the shocks forward plus had shorter ordinary oil girlings forward of that again to assist the piss poor damping of the main ones--did work ok as a stop gap measure till gas girlings came along. They lasted ok in the vertical position but didn't like being cantered forward too far or gave up pretty quick. Where i worked we were the NZ agent for Girlings & had truck loads of them. Got a pair on one of my relics that i put yamy gas valves in so i could change the oil & experiment & just gassed up with the compressor via a needle to 120psi [not ideal i know but nothing exploded--yet]. Anyway, where was i--lost.
  • Mugen ME480
« Reply #68 on: September 21, 2013, 06:31:13 am »
Here are some pics of the YZ-A stem for comparison
The top clamp is different also (smaller hole)
California, USA
  • Mugen ME480
« Reply #69 on: September 22, 2013, 12:18:58 pm »
I weighed the triple clamps I was going to use vs. the YZ-A set and there is over a 1 pound savings.  Adding up the weight savings with the items I have, my RT2MX Hybrid should be in the 210-212lb range.
Not sub-200 like Barry Watkins' effort, but pretty good for starting with a 238lb pig.  I'm foregoing the Ti axles and engine internals lightening to hold costs down.
California, USA
« Reply #70 on: September 22, 2013, 12:57:55 pm »
I'm aiming at the magic 200lb make with my RT2MX Jay but I'm at an advantage with the Chro-mo Hindall frame. I'm using mag Profab triple clamps, Can-Am back wheel, alloy YZ125-A tank, alloy seat base and little things like 'some' ti bolts, titanium Jones handlebars and hollow Chro-mo axles and swingarm pivot that came with the frame. I've changed the plans for my other almost identical Hindall and it'll get the hybrid DT2MX engine with YZ-A top end.
  • Mugen ME480
« Reply #71 on: September 22, 2013, 02:41:49 pm »
Firko,
It should be a very cool bike!  I'll post a Harry Hindall article I have.  He looks like he could step out of the pages and be some cool dude walking down the street today.  Is he still alive?
On a side note what ever happened with the McCook Racing website?
California, USA
« Reply #72 on: September 22, 2013, 03:39:40 pm »
Firko,
McCook only recently pulled the website after a year or two of inactivity. He's dropped out of the sport because of business taking up much of his time...he runs a big multi national electrical components company...and most of all, a racing back injury prevernting him from riding any more. He and I are still good mates, in fact he's going to stay at Casa del Firko over Christmas/New Year while down here for the holidays. He's selling up a lot of his stuff but is keeping his street trackers and café racers. The YZ125-A tank for my Hindall is from his stash.
Harry Hindall was indeed a cool dude with his beatnik goatee and polo neck sweaters. I'm a bit of a student of aftermarket frame maker welding and I reckon Harry's bronze welding to be the best I've seen except for Mark Jannink from Mojo frames in England http://www.mojomotorbikes.co.uk/home.html who's in a class of his own. Harry Hindall took his own life at a shooting range in New Mexico back in '02 or so.
« Reply #73 on: September 22, 2013, 05:03:52 pm »
Hey Marcos you should chase up old mate Ji for some up to the minute Titanium info. J
Offline yamaico
« Reply #74 on: September 22, 2013, 06:37:01 pm »
Hey Mark,
Where those YZA tanks alloy? I always thought they were steel for some reason,
Pete.
