Author Topic: NON VMX 2013 KTM 85  (Read 9740 times)
Re: NON VMX 2013 KTM 85
« Reply #15 on: June 30, 2013, 12:08:02 am »
Yeah I have a set of those on the way, turns out after going on the formula web site they also fit the same brake system to the 350 free ride...seems to be having the same probs...
http://www.youtube.com/watch?v=CFjejOkt7D8
Offline mickj
« Reply #16 on: July 13, 2013, 09:39:48 pm »
 Hi Mate heres the fix . Or one of them
 Disassemble to caliper & measure the pistons , side to side.
 I bet there oval, slightly.
 This is a known problem & they stick when ever they want
 Go to Pax racing or Powerband in the UK , not US, & order his stainless pistons
 Also you might try putting a insulator material between the pad & piston .
 That will help with pad heat transfer between the 2.
I use a ally coke can cut to the shape of the pad.
