Author Topic: Fuel Injection on muddaboiks?? Pro's & Cons  (Read 4715 times)
« on: June 28, 2013, 09:37:12 pm »
What is the current view in forum world on fuel injection???
I've had stuff all to do with it other than having to be real careful pulling the tank off after a bike went under in a crossing.
Lots of stress re filters and leads etc
bit like watercooling.... its perfect until there is less water in the system than needed then its totally useless :-\.
Any gains in "performance" over an aircooler is null and void when the aircooler runs on by while you sit in a steam cloud... >:(
is Fuel injection like this.. a gimmick foisted onto the public by keen ad men ???
Im keen to hear the majority concensus
Re: Fuel Injection on muddaboiks?? Pro's & Cons
« Reply #1 on: June 28, 2013, 10:24:58 pm »
It has no place on a dirt bike. Not yet anyhow.
I'm no anti-EFI Luddite - I've converted several cars to EFI.
But cars don't come with FCRs, aren't normally filled from jerrys, have much larger filters, and are rarely expected to run under water/in three feet of mud/etc.
They're getting better, but most older EFIs on bikes have abrupt throttle response, particularly at lower revs, making them much harder to ride in snotty spots.
Offline TooFastTim
« Reply #2 on: June 28, 2013, 10:42:09 pm »
I sort of agree. My gasser trials bike has throttle response as good as if not better than the FI Ossa. So no benefit in that regard. I don't like the additional complexity but I have to admit that water cooled, disc braked  bikes are a huge improvement over the twin shocks we love. Th only benefit to FI as far as I can see, is less emissions and if that's a sacrifice we have to make to keep 2Ts alive I'm prepared to make it
« Reply #3 on: June 28, 2013, 11:05:17 pm »
Run a good fully synthetic at 100 to 1 and the emissions (visible ones) disappear :o
I forgot about t he filtered fuel issues... never seen a clean jerry can that's for sure
« Reply #4 on: June 29, 2013, 01:03:41 am »
No con's all good if your a weekend trail rider on a 4T. On a 2T never unless you want to use a aftermarket ignition/injection module and burn holes in a few pistons
Offline Andrew L
« Reply #5 on: June 29, 2013, 08:54:02 am »
Spend the extra $70 odd for a spare fuel pump for the bumbag you'll be needing it along with a few fuses
« Reply #6 on: June 29, 2013, 10:11:24 am »
Spend some time and read some info from this website.
http://www.orbeng.com.au/
You can inject air not just fuel when it's done correctly combined with the lastest electronics you could build a electric smooth 70 HP bike that could get 200+ KM from a 12 litre tank.
« Last Edit: June 29, 2013, 10:15:00 am by Slakewell »
Offline pancho
« Reply #7 on: June 29, 2013, 11:49:01 am »
 Have a look at the Evinrude/Johnson Fict. fuel/air injection, for 2/  outboards. Interesting.
pancho.
« Reply #8 on: June 29, 2013, 01:12:58 pm »
Having ridden a few injected & carbed 450 enduro bikes there are advantages to the injected bikes, seriously easy starting below freezing point, no drop off in performance at altitude etc.
Never drowned 1 so have idea what they're like to dewater but would expect they should be easier due to not needing to drain the carb & clear out jets etc
« Reply #9 on: June 29, 2013, 02:17:16 pm »
I know several 4T owning trail riders who will disagree.
The reliability isn't there yet - crap in injectors, wiring rubbing through, dead fuel pumps, etc.
Plus the finer details of mapping for smooth, strong throttle response in all conditions is still a black art that very few have mastered (and let's be honest, plenty of car makers still haven't figured it out, over a quarter of a century after EFI became mainstream in cars).
Offline TooFastTim
« Reply #11 on: June 29, 2013, 08:46:04 pm »
Leave all the techno complications on the 4t's, I'm a 2t'er for no other reason than reliability and simplicity.....and did I mention power to C.C. ratio and weight ?
Offline BultacoMacca
« Reply #12 on: June 29, 2013, 09:37:51 pm »
 EFI is great when it's new, but I know of a number of EFI enduro/trail bikes that have had to be towed home. You get a bike that's a few years old, has been dumped in a creek, or washed thoroughly every ride, and you start to see connector issues.  Plus any wiring rubbing as Nathan said. Not to mention TPS values seemingly changing of their own accord, without the input of owners trying to "tune" the bike to a stop with aftermarket controllers. These bikes really don't have a complex sensor system, but you still arent easily going to do much to one without the OEM Factory Diagnostics. And the old "put on the Computer to see what wrong with an EFI bike" is pretty much a crock, as all you often get is a warning of a high or low voltage problem which then has to be solved by good old mechanic's knowledge and skills anyway.
