Author Topic: Pre 75 XL250  (Read 12641 times)
Re: Pre 75 XL250
« Reply #15 on: July 03, 2013, 11:28:33 am »
Back in the 90's I built a very stout XL350 motor using a box full of goodies I bought in the USA. I resisted going big bore and kept it at 350 but used a 12:1 Venolia piston, Megacycle roller cam and springs, ti retainers, Carillo rod, a very nice port job, lightened rockers and CT110 CDI ignition, 36mm Amal MK2. The engine hooted but because I used a non cush drive rear Bultaco wheel I had problems breaking third gear. I was looking into light cush drive hubs and had settled on a small Yamaha hub (can't recall what it was out of) but sold the bike before I bothered.
« Last Edit: July 03, 2013, 10:41:18 pm by firko »
Re: Pre 75 XL250
« Reply #16 on: July 03, 2013, 06:47:41 pm »
That would have been a hummer allright, no wonder third gear went west, they were weak at the best of times.
Offline 09.0
Re: Pre 75 XL250
« Reply #17 on: July 03, 2013, 06:58:38 pm »
Are you guys talking about keeping it in an xl frame? I have a big bore motor as well and an xl roller but keep getting told the frame is a piece of crap.
Offline jimson
  • Sanctuary point N.S.W
Re: Pre 75 XL250
« Reply #18 on: July 03, 2013, 09:16:20 pm »
090 the XL frame is okay just take to it with a grinder. Remove all unwanted brackets look at losing as much weight as possible. When you finished the race at the front of the field you know you've worked for it.  ;D jimson
Re: Pre 75 XL250
« Reply #19 on: July 03, 2013, 10:39:29 pm »
I've been around this sport since the beginning and during that time I've seen XL Honda motors fitted in everything from Elsinore's to Maicos to CZ's to Bultaco's to Husky's and others including C&J and my own Champion. Despite some of those swaps being successful, the most successful pre 75 4 stroke Honda's have nearly all had the stock frame. Steve Greentree and the Smith Bros from Victoria had the class at ransom throughout the 90's with stock frames XL's, the only the occasional interjection being from a CCM, BSA or Trumpy. Cut all the superfluous shit off the frame, use the longer 350 swingarm, gusset the swingarm pivot area to stop flexing, especially when big horsepower motors are used and use the best forks you can find, find the lightest cush drive rear wheel you can and bung it all together. They handle fine and they're not that heavy. The front brake is pretty handy too, second only to the Yamaha in my opinion.
Re: Pre 75 XL250
« Reply #20 on: July 04, 2013, 10:09:54 am »
Firko and I weighed a bunch of 4 strokes at Amaroo one time and the stock frame bikes were some of the lightest. You can get a stock frame XL 250 based bike under 100kg
Re: Pre 75 XL250
« Reply #21 on: July 04, 2013, 11:12:27 am »
Im with Firko, ive ridden lots of projects from cr based to even a 420 in a Montessa but they never had the balance that original xl frame had so yeah, give it an Enema and suspend it well.
Offline cloggy
Re: Pre 75 XL250
« Reply #22 on: August 19, 2013, 08:32:55 pm »
 What's the going price for a sorted stripped bike?
Re: Pre 75 XL250
« Reply #23 on: August 20, 2013, 01:12:05 pm »
Couple of cheapies on ebay at the moment with hot pipes and aftermarket shox, two for the price of 1.5. They need work but they look like a good start...
