Author Topic: Adjusting idle rpm on KX250A7 ?  (Read 7584 times)
Re: Adjusting idle rpm on KX250A7 ?
« Reply #15 on: June 28, 2013, 12:11:11 pm »
I'll adjust the idle by filing the slide.
Filing the slide cutaway?
No that'd lean it out at 1/3 throttle.
That's right.. I'm interested to know which part of the slide is filed to raise the idle? I can't see how filing it will lift it
« Reply #16 on: June 28, 2013, 12:26:38 pm »
A carburettor is just a block of alloy that mixes air & fuel together, there'll be a way  ;-)  Maybe modification of the bottom of the slide to allow some air through and pick up some fuel on the way?
« Reply #17 on: June 28, 2013, 12:29:14 pm »
You file the front to richen and the rear to lean. So front for idle
« Reply #18 on: June 28, 2013, 12:54:58 pm »
Interesting.. One of the bing slides I have for my 490 maico has a small notch filed out of the front of the slide but I haven't tried it
« Reply #19 on: June 28, 2013, 01:40:38 pm »
IMO that would be to help it from stalling in heavy breaking.
« Reply #20 on: June 28, 2013, 02:03:06 pm »
I think I'd rather run a small groove from one side of the slide to the other (in line with the port), above the fuel outlets, varying the depth depending on the desired idle rpm.
« Reply #21 on: June 28, 2013, 02:05:34 pm »
Just for convenience, either putting my goggles on at the line or if I crash in a race, those few seconds of idling can save some hassle.
« Reply #22 on: June 28, 2013, 10:51:05 pm »
I always have my 250 and open class MXers set to a dead trottle (not idling) anyway. 250 and in particularly open class bikes tend to push (understeer) in slow corners when they idle. Just my opinion from a mid fielder ;)
You idle through the corners and are still a mid fielder....
