Author Topic: swaping cylinders  (Read 9680 times)
swaping cylinders
« on: August 16, 2007, 07:57:46 pm »
Is it possible to fit a cylinder from an '81 490 on to an '82 490 motor ?
And what other differences are there between the two....anything that would cause scruteneering issues at a title event such as tassie?
090
Re: swaping cylinders
« Reply #1 on: August 16, 2007, 08:21:42 pm »
I have an '82 motor in mine and it is legal. Not sure if they interchange but i would guess that they would
« Reply #2 on: August 16, 2007, 09:22:22 pm »
Even though it's a motor derived from a pre '85 bike?
Maico31
« Reply #3 on: August 16, 2007, 11:25:41 pm »
The motors are the same although the '82 supposedly has slightly different porting.
« Reply #4 on: August 17, 2007, 06:42:58 am »
Oh! When did Maico go to reed valve?
Offline xel93
« Reply #5 on: August 17, 2007, 08:38:47 am »
The 82 cylinder bolts straight on.  It does have slightly different porting and produces more torque - it is noticeably better than an 81 cylinder.  Stock reeds came in with the change in motors in 83
« Reply #6 on: August 17, 2007, 10:59:15 pm »
The 82 GS 490 Enduros had reeds. All 81-83 cylinders are interchangable.
« Reply #7 on: August 18, 2007, 12:44:31 pm »
I realise it's not really an issue at club level, I guess what I am tyring to find out is if I was to venture to Tassie for the titles, would a reed valve "Pre 85 " barrell be allowed in the evo class?
Maico31
« Reply #8 on: August 18, 2007, 06:30:14 pm »
I would think that a reed valve cylinder from a '82 490 enduro would be legal because that bike was still a twin shock.
East Coast Maico
« Reply #9 on: March 28, 2011, 10:03:00 am »
In the States the reed valve bikes with Magnum engines were 1983 Spyder E. is was basically a 82 enduro with Ohlins shock and the reed cylinder. Hard to find around here.
Bill
