Author Topic: CZ Mikuni Jetting Specs as a reference  (Read 8194 times)
Offline Husabergpete
« on: May 31, 2013, 06:58:13 am »
Based on a 36mm Mikuni for 250 and 400 info supplied by Adrian who got it from a spec sheet from back in the day.
250 Motor
Main 260
Pilot   35
Needle Jet Q 5
Needle  6FJ6
Slide 1.5
Alternative from a Euro Web site
Main 250 but not smaller than a 210
Needle Jet  Q 5
Needle 6DP5
Pilot 35
Slide 2.5
400 Motor
Main 280
Pilot  25
Needle Jet Q 5
Needle 6FJ6
Slide  2.5
Just about to fit a new 36 Mikuni to a fresh 1973 250 MX. Will give this post some feedback once it is running and if we need to make changes etc
Pete
Offline GD66
Re: CZ Mikuni Jetting Specs as a reference
« Reply #1 on: May 31, 2013, 09:29:24 am »
« Last Edit: May 31, 2013, 09:31:12 am by GD66 »
« Reply #2 on: June 01, 2013, 05:09:16 pm »
Have seen the specs off the braigasen site & only some show really lean pilot jets, my 380 uses a #45 in it's 36mm carb which is what the grand prix cycles(moto-x fox) guys suggested in the 70s. 250 was similar
Have a look at www.czmadness.net in specs to find their jetting specs
« Last Edit: July 03, 2015, 12:17:21 pm by tony27 »
« Reply #3 on: August 08, 2013, 10:23:43 pm »
Now running a 250 Main and the clip one above middle of needle.
Betta
Offline Tim37
  • Its an investment ...had to buy it !
« Reply #4 on: August 26, 2013, 08:00:11 pm »
Hi , I used to race a few CZ,s for about ten years from the early 90s and remember trying all sorts of carb sizes on 250s and 400s , Interesting to hear you have a 36 mm on a 250 ...they need major port and pipe to support a 36 mm a 32 or 34 will make most guys quicker .... I still have a works 250 with a reed and massive ports ...goes best with a 34 for real world riders unless your doing dirt track .   I used to run a 32 on my 360 sidepipe it was fantastic .
Bigger is not always best ...
